Project Information
I was asked to make a small occasional table, similar to one posted prior, as shown in the first photo, but with smaller dimensions to accommodate it's permanent location.
Taking this opportunity to try something new, I decided to try my hand at off-set turning, also referred to as multi-axis turning. This then creates a Queen Anne pad foot type cabriole leg. Off to the lumber yard for some select cherry, 4 quarter and some 8 quarter.
I found very little web information concerning the "how to", but what I found was pretty well explained & easy to follow. Some of the web instructions can be seen in photo 4, from two separate sources. Photos 5 and 6 show the locations of the second set of centers, used to create the taper that veers off to one side & creates the pad foot.
While doing this turning, I tried both sets of instructions - each on two legs, which differ in their determination of the off-set, and due to this I created two sizes of pad feet, which can be seen here:
Note the two on the left match as do the two on the right, with the right being slightly larger. In as much as I had already turned two practice legs, one in cherry & one in pine, I decided not to waste these and put the matching pairs such the two that match are in front & the other set is against the wall. Nobody knows the difference.
Last note to anyone wishing to try this, note the bottom off-set in photo 6 and how close it is to the side of the bottom pad. One set of instructions stated that prior turning this little pad (with the true centers) you may want to wait until the off-set turning is complete, so as to avoid the possibility of this second breaking out. I had this happen - the tail stock broke out of it's setting, but stayed anchored sufficiently that I continued to turn until I noticed I was creating a leg with a "S" shape. Wasted some cherry wood on this.
The finish includes H. Behlens (now owned my Mohawk) Cherry dye, and General Finishes water based top coat.
Thanks for viewing, any questions - just ask.
