Project Information
I am about 1/3 done on the trim work for the entertainment center. When finished there will be 4 runs of trim that follow the contour of the cabinet. One base, one crown under the counter top, and the crown at the top will be 2 piece of the same base and crown, but with the base upside down. I also added some more 3/4" poplar around the base of the shelf uprights to give them some added weight, and put some trim on top of them. I am thinking of adding some of that same small trim to the inside of the face frame on the ends of the cabinet, but am afraid it will be a tad to much. I kind of like the simple lines of the end face frames. What do you guys think. Trim the face frame or no?
Gallery
Comments
I have seen some built-ins similar to what you are doing in style. That would be paint grade with all the stacked trim. The frame and panels usually have a small trim running around the inside of the frame. You can always get some trim, cut and friction fit it in to see if you like it.
Anxious to see this progress.
I agree with Todd, I think a little trim on the inside of the frame might look better.
Great job. Keep us informed.
That's a good idea, Todd. I will post some pics with some trim in them and see how you guys like them.
nice work!
i sometimes will use a rabeted panel moulding insde the panels as well. or a simple base cap is nice
Rob, I'll be looking for your shots.
mrtrim you freak me out.
