Project Information
My projects are moving more along the hybrid method so I needed a work holding bench for hand tools. I chose the style similar to work benches we had in school in England, with a Record style vise. I wanted the top to be sacrificial and easily replaceable and no metal in the top. The leg structure is bridle joints and through mortise and tenon. All are draw pegged and the tenons are wedged. Stretchers are mortised into the legs and bolted so I can disassemble the bench and tighten the legs if they get wobbly.
I can disassemble the bench in under 10 mins with 3 sockets, an impact, two wrenches and a screwdriver.
The legs are poplar, the top and aprons started as 2×12s from HD. I bought 8 2×12s which were pretty cupped so I cut them down the middle, planed and jointed the edges and glued them back up. Then I stabilized all the knots and holes with epoxy. Finish is BLO and varnish for the legs and the top is dark walnut Danish oil I've had sitting around for years.
I use dogs a lot as stops or clamping elements, and I will be buying some hold fasts, but I am not a fan of the 'Swiss Cheese' look of some work benches so I will drill holes only as I need them. In researching how benches were used in factories where hand built furniture was made by craftsmen on piece work, they usually had 5-8 holes in the top and a few in each apron.
It's usable, but not finished. May never be finished. I plan to add a planing stop, some drawers under the top and a shelf in the stretchers. I have no need for a granite plate flat top to my bench as I have another work table that is dead flat for when I need that sort of thing.
Gallery
Comments
Good work on the bench
Beautiful bench.
Fine work.
The more I see these English type benches, the more I like them.
Best thoughts,
Mads
Thank you, Gentlemen … I'm quite proud of it and cutting my first dovetails on it …
Very nice work.
Looks great!
I want to build a bench like this but I'm am confused on how to install the vise. Looks like the apron would get in the way of the bolts that go into the table top from underneath (e.g. looks like you'd be screwing vertically into the apron and need to cut out a bigger piece of it underneath the vice to be able to screw it in).
