Project Information
This is my first attempt of making an end grain cutting board made of walnut with maple inlays. It is mostly made on my homebuilt CNC. The inlays are made from solid maple blocks, because I did not want any visible seams in the inlays. Therefore I had to split the pattern into smaller segments and glue them in two runs. The slope on the side of the inlays made the walnut/maple seams practically invisible.
There are a few more pictures at my blogspot if you are interested:
https://maskinkonst.blogspot.com/
Gallery
Comments
Cool!
Great idea with the tapers, just like veneer inlays only on steroids. Unlimited design potential!
THAT IS A BEAUTY!
Premium Member
nice work,love that inlay design.
sure is purdy, nice design,
rj in az
That is really cool!!!!!!!!!!!
Cheers, Jim
Great looking board. Nice job on the inlays.
Very elegant pattern, well done. Is this board strictly ornamental or will it be subjected to moisture/water when used/washed? I ask due to the differential movement of end grain v what appears to be face grain (maple). Seems like a high potential for checking/cracking. Has this technique been successful for you in the past? Thanks.
Hi, I am glad you like the board! This is my first cutting board with inlays, so I do not have any real 'field experience'. It was a present to a relative that got married this past weekend, I really hope they will use it for cutting.
The maple is actually also oriented with the end grain up, the same direction as the walnut base. I hope that minimizes the risk for cracking. Thanks for pointing it out, I will look out for any such problems.
//Henrik
- kaetamer135
