Comments
What is the wood type and dimensions?
Pretty dang cool BT.
Would love to see a process video. It turned out great! What speed were you turning the eccentric cuts at?
Thanks for sharing.
- Phil32
I am not sure with the wood type. It is a crotch area. The diameter is about 6 inches. I may try a bigger item with the asymmetrical chuck but it would be more challenging.
Thanks for sharing.
- MrWolfe
Thank you for the complement. I hope to demonstrate with a video when I get a camera on my lathe. I turned this piece at about 700 rpm. When balanced well, you can turn at a higher speed. Another dish I could rotate up to 1,100 rpm before the lathe vibrated.
Premium Member
thats damn cool,i can only dream….someday maybe!
I thought it was turned by an eccentric!
Premium Member
Definitely different looking and a good job doing it. Thanks for showing. Mel
- pottz
Thanks! This kind of turning needs some skill because the gouge cuts the wood and spends some time in the air. Turning natural edge bowls would be a helpful step before this eccentric turning.
- mel52
Thank you for watching my project. As I am using this chuck for the first time, it is fun to see how the outcome looks like.
