Project Information
I've been experimenting with Ebonizing different woods naturally. Through trial and error I have arrived at a good technique. First I let some steel wool sit in vinegar for a few days then I make a jar of really strong black tea and cool it. I saturate the wood with the tea first to elevate the tannin level (if needed - online data bases will show you the Ph of different woods). Once the wood is dried with the tannin treatment I saturate it with the vinegar solution and it immediately starts to darken but need to be left overnight for the best results. The next day I just rinse the wood off and (if you are using veneer) flatten it under anything flat with weights and let dry. The wood is ready for working.
This is a 1.738" wide bangle with Ebonized Karelian Birch and a Zebrawood Lining. All steamed and bent. Using Gorilla Glue for the bonding and Behlen Wood Turner's Finish, 3 treatments then micro-mesh polishing. I finish it off with Behlen Lacquer Topcoat.
Man I wish the pics were better, it's really hard to photograph figuring but the Birch ebonized is the BOMB.
Gallery
Comments
Really beautiful. I almost think the interior needs to be on the outside as well or perhaps as its own piece. Great description of the work required to attain such a piece.
I have made a few with Zebrawood: here's one on a Stainless core. My wife reacted to this last Double-wide creation very favorably (she's my test lady). So I will probably be making several models of the double-wide with different woods for custom order at etsy. and YES Zebrawood alone will be very nice. I will be sure to do that as well. Thanks for your comments cmmyyakman.
Beautiful.
Bob.
Love the ebonite birch. Great work.
nicely done, interested in your process, will have to try that sometime, as I mainly use birch for my projects, Basically free, I cut it fro my own place and sawmill it myself.
@ Bushmaster : I would love to see a much larger piece with this treatment! I am not a reliable carpenter or cabinet maker, I just have never been taught. I'd be glad to share IN DETAIL whenever you are ready. First thing you need to know is that most white distilled vinegars are already a 5% solution. You do not need to dilute any further. Get a
jump on it by corroding some steel wool in a jar of vinegar and just leave it. (no need to ever remove the Steel wool.)
