Project Information
Turned vase from Alaskan birch.
The piece was end-turned from a large chunk of green birch. I spindle mounted the blank, turned it to rough and put a tenon on what would become the bottom. Reversed it into a four-jaw chuck and hollowed with a combination of an end-grain termite cutter and a Sorby goose-neck hollowing tool. Once it was hollowed and shaped, I decided that I didn't like it. Seemed like it was missing something, so I parted it in half at the shoulder and glued in a piece of walnut I had in the scrap bin as an accent ring. I liked that much better and it lengthened the vase by two inches which I thought worked better with the overall design.
Next I put it aside in the drying cabinet for a couple months until it was down to 8% moisture. I then turned it to finish and sanded it down to about 600grit. Next I applied several layers of aniline dye in different colors (black, red, and yellow), sanding and carving in between applications. The finish is several coats of wipe-on poly gloss.
It's about 24" tall.
In the sunlight it is spectacular.
Gallery
Comments
· Registered
Awesome vase! You do great work with a very creative eye! I am making you my buddy so I don't miss any of your postings.
Erwin, Jacksonville, FL
· Registered
An outstanding turning and the use of color and grain has a great appeal! Good Job!
· Registered
Looks great! Nice ad lib in progress there. Love it…..........
· Registered
Wow another amazing piece. fantastic finish.
· Registered
wonderful job, thanks for sharing the process.
· Registered
Another stunning piece of art. Great turning. Great eye for detail.
Keep it up.
Scrappy
· Registered
Another great one! Heck it looked great unfinished on the lathe!
· In Loving Memory
That would be spectacular in any time of day or night, absolutely gorgeous, you went way out with this turning, kudos.
· Registered
Amazing! The colour of this is absolutely ….....................................I'm speechless.
· Registered
Wow nice! How many hours does that take?
· Registered
Paul, actual work (turning and finishing) was probably 40-50 hours. Including drying time it was over a year.
· Registered
You need to stop doing these!!! It makes me feel like the amature that I am. I am astounded at your work you do amazing things. Thanks for the inspiration
· Registered
Just amazing. What is a termite cutter?
· Registered
It's an end grain hollowing tool. Woodcraft carries them But if you know a metal worker, you can make your own.
Makes end grain hollowing a whole heck of a lot easier, especially for deep vessels.
