Project Information
End-grain hollow form turned from a piece of Ash, finished with wipe-on poly.
The color is KEDA alcohol-based aniline dyes, mixed with a bit of clear shellac (about 1 part shellac for 15 parts dye). I applied the color, fired it with a lighter, then knocked the piece back with 320 grit. I repeated the process with a different color, using red, and yellow in that order. I sanded to 800-grit, and finished with 5 coats of wipe-on poly.
The use of shellac with the dye is something I learned from Jimmy Clewes. He says the shellac binds the color to the alcohol, which aids finishing process … with each coat of color the wood becomes more progressively sealed, therefore the later colors soak in less.
