Project Information
Thien dust collector
This thing works great!
The goal was to have it function well but also look like it belongs on top of the trash can. I mainly mill foams like eps and urethanes with my cnc. With that material being so light I was a little worried about a lot of it going directly into the vacuum instead of the can, but the vacuum is empty every time I check it except for maybe a few small pieces of foam. One thing I did have to do was reinforce the trash can on the inside. I used basic fiberglass mat and resin from Home depot. Had to put 3 layers on the inside to make it stiff enough. The only thing I would change is making the top plexiglass window out of a thicker piece. Its 1/4" but flexes downwards about 3/16" when the vacuum is turned on.
Made to fit on a brute 32 gal trash can
Pressure fits onto trash can with no obvious leaks
Made of 0.75 MDF, 0.25" plexiglass and 0.125" plexiglass
Vacuum system used is a Rigid 6.0 wet/dry
Vacuum ports are 3" to 2.5" to fit the standard vac connectors
Brute trash can was reinforced with fiberglass on the inside to stop it from collapsing.
Gallery
Comments
Oh. This is a "cyclone" collector, not the fan housing…
Had me going for a minute.
Looks purty! I see a bafffle in there… How well does it work?
Beautifull stuff! I like the colour.
