Project Information
I decided to build an actual dust collection for my tablesaw and jointer. I used some scrap 4" PVC pipe. I cut into the pipe about 1" deep. Then I took it into the kitchen and heated it up on the stove (of course I waited until the wife wasn't home!). I slowly heated it and bent one tab at a time (be careful because the PVC can burn easily). How're I realized that the pipe wanted to go back to being straight when hot. So when I bent one tab, I had to go back and bent a few tabs before. Once everything was close to being completely bent, I heated the whole pipe and put some weight on it to let it cool with the tabs fully bent. I screwed it to the plywood enclosure I made and caulked it to make it completely air tight. It took me about 2 hours to build two of them.
Gallery
Comments
An interesting project and one I would not have thought of. Would something like this worked?
Sorry I have to ask, but can you show a picture of where you used it on the dust collector?
I usually cut little 1/2" or whatever pieces off
of a coupling and glue to both sides of a exact
size hole, nice clean look and it will still swivel
if need be. Not sure of your application though.
Yours looks good to me, Nice job.
First of all, this project isn't supposed to be posted in this section as it contains no wood.
Second of all - THIS IS HIGHLY DANGEROUS!!!!!!!!! PVC, when burned outgases compounds including carbon monoxide, carbon dioxide and hydrogen chloride. Don't Do This!!
It worked well for me. You don't actually burn the PVC. You heat it up until it reaches the glass transition temperature, which is only 176F. I experienced no fumes or any off gases created in the process. The connection is mounted to a plywood enclosure I made for my grizzly tablesaw. I cut out a whole and slide it in.
Great idea! I heat weld and melt PVC for a lot of projects such as bows. A heat gun would work better!
Premium Member
It looks like a great adapter.
You heated well above 176 F based on the burned areas. If I were going to do this I would do it outside and be upwind.
It would be better to not do this in a living space and especially not where you prepare food. I think it is better to be safe and not take risks with these type of toxic gases.
You can get a metal starter from Lowe's for less than $10.00 and you will not have to go through such a process and take a chance on burning the PVC.
Scott, I think your idea is very innovative and it worked for your needs.
I needed to expand some PVC to fit on some China made fittings, so with the heat gun and a chuck off of the lathe, I was able to soften it and expand the pipe just enough…
I too would like to see how you used this creative flange.
