Project Information
Replica of a C.1840, J. N. Dunning, Burlington, VT, 8-day "Parliament" style wall timepiece. Walnut with walnut burl waist and door. I even emulated the cracking and separation that occurs on burl veneer of this age. Pendulum driven works. Lots of band saw work on cutting out the lower parts!
Wood: Walnut and walnut burl veneer
Tools used: table saw, miter saw, band saw, scroll saw, thickness sander, finish sander, thickness planer, router, jointer, shaper, 1" belt sander, oscillating spindle sander, hand chisels, low-profile block plane, glass cutter.
Finish: Mohawk tinting sprays, shellac. (No Minwax found in this shop!)
Gallery
Comments
That is one cool clock
You do beautiful work, my Friend!! Thank you for sharing it, and welcome to LJ"s…
Great clock. You really acomplished the "old" look.
I also like the way your are including your materials and tools used. More of us should be doing that.
This is great Jim even the ageing
Another fantastic piece Jim. Glad you came to the Arizona Picnic and joined LJ's.
Keep it up.
Scrappy
Jim, that's awesome!.......in every detail. Very, very nice. Thanks for sharing that with us.
Great work. It looks like an antique. I'm curious about the movement and clock face which has a parchment look to it. I also second LesB's comments on listing your materials and tools.
The movement is an antique 8 day time only one I already owned that had the correct drop. I try to use the correct antique movements with the cases I build…..if possible. Since this is a museum piece (the one I used as an example sold for $45,000 at a high-end auction!), I did not have a similar hand-made movement by Mr. Dunning. The face is a purchased paper face. Since this is a 14" dial, I could not print it on the computer like I do many times. I use both purchased paper faces and special paper faces I design in MS WORD (Word Art) if I do not have the correct manufacturer's trademark face in my stock. It is then aged with mechanical wear spots in the correct locations and with stains to simulate age.
Amazing work, you could do replica work and fool the best of them.
