Project Information
Made this DP table for my new (used) drill press. I incorporated a few features from different plans. Instead of cutting a dado slot for the t-tracks, I built up the surrounding areas with 3/8 birch plywood. This made it easier to create the center removable insert, which I made 6 extra ones while I had the saw set for the bevel angle.
Gallery
Comments
Nice accessory. I have one and it works great.
In Loving Memory
Nice! I need one of those!
You did a great job on a very useful accessory. I like the method of laminations as you described. I may have to go that route when I finally get around to making one too.
Glenn, Welcome to LumberJocks. Very nice looking drill press table, should serve you well for quite some time.
CtL
I did the same sliding inserts…............ have different ones for sanding drums, etc.
Love them.
Good job.
Looks very nice. I made one a couple months ago. Simple yet works very well. I can't believe I have done without one for so long.
Nice looking DP upgrade, It will make all of Your drilling Ops that much easier and accurate! I put one together much like Yours and I use it all the time.
Welcome to LJs! Nice DP table.
Glenn,
welcome to LJ. I am relatively new too, but one thing I have come to realize is that the folks here are genuinely kind and interested in your work! You will find a welcome home here! Nice work on the table too:).
Very Respectfully,
Nate
Perfect drill press table. Enjoy it.
Very nice work. I am adding it to my archive of DP tables for the day I am finally ready to build mine. This one goes near the top of the list.
