Project Information
I made this dresser/ bookshelf, with an attachment (future keepsake box) to raise the height of the changing pad an additional 6", for easy access to the baby. Once my daughter finishes using it as a changing table, the attachment can be removed and rolled under a bed for storing my future grandson's keepsakes. All cherry wood and used dominos for joints. Hope you enjoy.
Gallery
Comments
Nice build.
Plus Liam can swim in the aquarium when he's bored :)
That is very cool and very well made. nice work on it…..............Cheers, Jim
Very nice.
This isn't a criticism, but are you worried at all that while it's being used as a change stand, the exposed area of the cherry dresser top will age, leaving a lighter rectangle when the change table addition is removed?
I've avoided cherry on projects that change configuration for this reason, most notably a convertible crib/toddler bed/bed.
That actually never crossed my mind, but very good point. Typically the tables aren't used that long, so hopefully it will only be there 6-8 months, plus the window is not real close. If there is a slight difference, it should balance out relatively quickly.
Thanks for looking!
