Project Information
I bought a beat up dovetail saw on eBay. Put a fairly minimal bid on it (it was $25 with free shipping) and won. It's shown in picture 3. My goal was to have a saw I could practice sharpening and other saw maintenance tasks on, and not feel too bad if I screwed it up.
When it arrived, almost a year ago, the handle was even worse than it had looked in the photos, and was just too small for my hands, so I set the saw aside for a while and got on with other projects. Recently, I got "stuck" during my build for the Plane Swap and needed to work on something else while I thought about how to get past the problem I had created for myself.
I sat down and tried to unscrew the saw nuts on the saw I'd bought. Turned out they were rivets. I ended up destroying the handle I order to get it off, and the holes in the plate were pretty nasty looking. I filed the holes flat (they looked like they'd been punched through the metal, rather than drilled) and started shaping a new handle.
I traced the handle on a Bad Axe saw I bought, which fits me pretty well, onto a piece of 5/4 curly cherry I had. There was a knot in it, but I put that in the section that would end up "inside" the handle.
Then I did some shaping with files and such while I waited for new steel saw nuts to arrive in the mail, and then again while I waited for a 3/16 carbide drill bit to arrive after I'd mistakenly ordered a 3/32 bit.
I also pulled the back off the saw plate and cleaned up both the back and the plate. There was a fairly generic "Warranted Superior, Sheffield" etch that was almost gone (or had been etched lightly to begin with). I sanded it away, rather than trying to preserve it. I'm pretty sure this was a post-WWII saw, and nothing special, given the red plastic washer in place of a medallion and the riveted saw nuts.
I got the handle mostly shaped by the time the new saw nuts and drill bit arrived, so I was excited to get things put together. But I'd finished the handle at about an inch thick, which fits my big hands pretty well, but didn't fit the 7/8" long saw nuts I'd bought. D'Ohh!
So I took the handle to the belt sander and thinned it up a little. Which turned out to be good, since when I sawed the slot in it, I'd gotten it a little bit off, and it was off-center and aimed the blade a little to the right. Sanding the handle down let me fix that.
Then I had to reshape and re-oil the handle, but I did that with it on the saw. That let me test it as I went, making sure that it pointed straight and felt right. Last step was cutting chamfers at the top of the handle where the back went into the wood.
A couple coats of BLO later, and the saw is in use in my collection. And I learned quite a bit along the way, and have a saw I can practice sharpening on without worrying about destroying an expensive saw.
Gallery
Comments
· Registered
Good resteration job Dave.
· Banned
nice work my friend.
· Registered
Very nice restoration Dave, I like the new cherry handle. I've also tried sharpening hand saws, found it much easier than I originally thought. I suppose you have the instructions for saw filing, but if not you can find an excellent tutorial on Vintage Saws, web address is : http://www.vintagesaws.com/library/primer/sharp.html
· Registered
Great job on the restoration. Handel looks really comfortable.
I have a few flea market finds that I need to work on. 14" and a 10" hand planes. I am going to try to do electrolysis for cleaning up the rust. I do not want to remove any etching to determine what the brands are.
· Registered
Nice job. Thanks for sharing the process pictures too.
· Registered
Nice saw rescue.
· Registered
Nice job, reminds me I still need to make a new handle for a 2 Cherries blade I bought a while back:)
· Registered
This looks much better than a quick restore job Dave, basically a new saw. Good luck with your sharpening techniques. I bought a couple 2 man saws awhile back and restored them for display. I sharpened them myself and they cut decent but nowhere near professional quality. Just wall hangers.
· Premium Member
Thanks, Oldrivers!
Thanks, Pottz!
Thanks, Tom! When I bought that board of cherry, I was planning to use the end with the knot for a handle or tote or something. For sharpening, I've watched Andy's videos, and read up plenty. Just need room to set up my saw vise and the time to practice.
Thanks, Eric. I basically took one that I knew worked for me, then copied it and shaped it to make it comfortable. And yeah, I would've worked more to preserve the etch if it hadn't been a cheap saw.
Thanks, Barb! Glad to! I take a lot of pictures on most projects to help me remember what I did along the way.
Thanks, swirt!
Thanks, Andre! I've got a gent saw I was thinking of rehandling, but I find that the way I use it, the stock handle might be fine. Horses for courses…
· Premium Member
Thanks, Dave! It's hard to say exactly how much time went into it, as it was sitting in a corner of the bench for almost a year. I'd fiddle with it now and again while waiting for glue to dry or when I needed to think. But yeah, it's gone from a basket case on eBay to a great user. And I won't hesitate to sharpen it myself when it quits cutting well. Worst case, I can always move the handle to a new saw plate.
· Registered
Very nice replacement handle and great that now it's a good useable hand tool.
· Registered
Nice job Dave.
I'd practice sharpening on a saw with bigger teeth, anything above 13 tpi is a PITA (although, that's probably at least partly my eyesight) :)
· Premium Member
being an underacheiver, I would hire the sharpening but there are people like you Dave that challenge themselves at every turn and I do admire that. Great job on the handle !
· Registered
Fine work Dave! Anything to rescue an old tool it a worthy goal in my mind, gives you some insight into the design and construction. Double points for getting to make a part to fit your hand!
Just wait until you get that saw perfectly sharpened, and the word gets out, and all your neighbors bring by their saws and garden tools for the "Dave" treatment! 8^)
Only one year of sitting in the corner? She's barely had any time to acclimatize to your shop! I like to work in units of decades.
· Premium Member
Thanks, Mike. I'm nearsighted, so if I take off my glasses and get about six-eight inches away, those teeth look perfectly manageable. Of course, I might end up poking myself in the face with the file…
Dick, I've sent saws to Bob up in Missoula for sharpening, but he often gets busy enough that I'd like to be able to touch them up myself, and only send them to him after a few of my sharpening attempts have gotten things really challenging. ;-)
Thanks, Splint! At one point in my old place in Minneapolis, I thought about doing lawnmower blade sharpening in my garage every spring. I did my own mower every year, and one of the neighbors caught me at it, but he'd already taken his to the hardware store for that year. And then I moved away. But here, there's less of a market for that sort of thing. People who mow the desert tend to use the big brush-cutter type mowers that tow behind a tractor and have blades six or eight feet across. I've got no urge to sharpen those. Plus there's a guy who sets up outside the grocery store every Saturday morning to sharpen kitchen knives and scissors and such. We'll see, I guess.
I've also got five transitional planes (which will probably make three good users and some spare parts), three braces, and two egg-beater drills that all need a good cleanup at minimum, all arrived in the mail within the past six months, so I imagine I'll be bumping up the units of wait-time. Mañana.
· Registered
The handle looks like it was made by a master handle maker. Well done Dave.
Have you sharpened it yet? And what type of file will you use?
I like the BLO finish it's a great finish and the handle won't slip out of hand.
· Premium Member
my paws love a bigger handle also GREAT JOB :<))) GRATZ TOP 3
· Premium Member
Thanks, James! Haven't sharpened it yet, but I have a whole set of files from Germany. When COVID cancelled my saw-sharpening class at Bad Axe last summer, I took the refund in files.
Thanks, Tony! Having tools that feel right… just feels right!
· Registered
Dave I bet you're getting good at sharpening the saws. I'm sure there's a knack to it and being persistent
will prevail. I remember the first time sharpening a chain saw chain, I made it worst. Now I sharpen them like a pro.
Keep up the good work.
