Project Information
Some 60+ years ago, my father built a roller topped deadman stand to use as an extra hand working long stock on his ShopSmith and generally working projects around his shop. I have no idea if he built it to plans, or designed it himself. I still use the little roller top at some point of most every project. It is strong and light, easily moved around the shop, and easily transported if working off-site. It measures 20 inches wide, and 32 inches tall (collapsed), extending up to about 43 inches fully extended. The roller is 18 inches wide.
My son, Grumpycub, has seen the little stand in action for years, and has often said that one day he was going to build a similar stand to use in his shop. He stays pretty busy on many other projects and has never had the time to build the stand. Back in September, I decided to replicate my father's build as a Christmas gift for him.
The original stand is made of Red Oak, with a Pine roller. I had enough quarter sawn White Oak on hand to build the stand, and turned the roller from Southern Yellow Pine. I finished it in BLO/SatinPoly/Mineral Spirits in a 1:1:1 mixture. Over the 60+ years the finish and wood of the original have darkened to a deep, deep brown. The replica is pretty light in comparison, but the white oak is beautiful under the clear finish so I did not stain it.
I hope my son gets many, many years of use from the little stand. Merry Christmas, Grumpycub!
Gallery
Comments
Great story, great build. Passing down skills and tools, what could be a better way to enjoy the hobby.
Needless to say I was taken back when I saw this gift. I have memories of the original in my grandfather's workshop and as already stated, Dad has had it for years. The fact that it was built by my grandfather gave it an edge over other roller stands. Having one built by my Dad is truly special and every time I use it I know I'll be grinning. Thanks for such a special Christmas present and rest assured it will see lots of use!
Great job and story, going to fav's and will be on my to build list in the New Year.
That's pretty cool. Thanks for sharing.
I built one when I got my ShopSmith in 1978. I replaced the roller with roller bearings. These days it mainly gets used at the miter saw.
Thanks for all comments and views. I was particularily blown away by the number of views.
becikeja - should you build the stand and want more detailed dimensions, just let me know.
Idk - my stand also gets a lot of time holding lumber to feed into my miter saw. But I tend to use it whenever I am working lengthy stock such as positioned as an in-feed at the table saw, and even an out-feed on the jointer (not easy to set up, but doable).
Thanks again for the comments,
Ed - Kathleen, Ga.
Andre - should you build the stand and want more detailed dimensions, just let me know.
Thanks for viewing and for your comments,
Ed - Kathleen, Ga
