Project Information
I built this deadblow mallet with *********************************** for the head, and hickory for the handle, wedged with a little bit of walnut. I followed a plan that I had saved on my computer from a long time ago, from Shop Notes magazine? I can't find the original plan anymore, just the scan I have. The pockets inside the mallet are filled with steel BB shot. If I made another one, I think I'd use lead, because this hammer sounds somewhat like a baby rattle when you swing it. I think that lead also has less "bouncyness" to it than steel. I just used BB's because that's what I had on hand. I faced it with leather and rubbed on some finish. It was a fun build, and I am looking forward to tapping together some fine handcut dovetails with it soon. Ha! Or something.
Gallery
Comments
· Registered
That is one beautiful mallet!!
· Registered
Great looking mallet. It should give a mighty blow.
· Registered
Too pretty to use!
· Registered
very nicely done!
when you get done hammering can you use them for mariachi? with the pellets and all.
· Registered
Nice looking mallet, but although I comprehend the theory of the dead blow principal I have always found that if you need to hit something that hard it most likely wasn't built right?
· Registered
Thanks for the comments, all.
Andre, I'm not an expert, but I think the theory behind the dead blow is that it gives less rebound, and also gives the impact over a longer amount of time. (Which makes sense, if it doesn't bounce off the object you're striking). All that I know is that I can tell the difference when using a dead blow - it seems to do more moving (impact) for the same weight of standard hammer. I've also ruined a lot less things with a dead blow!
Finally, I totally agree with you: if you've gotta force something together, you've not done your job right…
· Registered
That looks great. That head will definitely stand up to some pounding.
· Registered
Very nice hammer! I made one for a prior swap and was not happy with it so I kept it and made another. They work really well!
· Registered
Nice mallet. How difficult or easy was the *********************************** to work with?
· Registered
- woodbutcherbynight
The initial cut off the big 3" thick block bound up my saw spectacularly, but after that cut, I didn't have any troubles cutting or shaping. Its really pretty wood, IMO.
· In Loving Memory
PPK , nice job and congratulations on your 'Daily Top 3' award.
· Registered
Nice job! I'm reinspired to make one out of a bunch of Ipe scrap I have.
