Project Information
This is a custom walking stick made for the same client who commissioned Walking Stick #060 http://lumberjocks.com/projects/22478. She can not put pressure on her wrist as needed when using a waist high cane so she uses an elevated walking stick to hang her hand from the top which eliminates the stress on her wrist. She had admired the technique used in the Banksia pod Cane #033 http://lumberjocks.com/projects/11521 and the Wood Lover's Faberge Egg http://lumberjocks.com/projects/10450 and requested a walking stick made with the same jeweled appearance.
The Banksia pod is first shaped to fit the client's hand which requires removing all of the exterior material that is soft and unstable. The holes house the seed pods and are quite hard. They are filled with various colors of epoxied sawdust and melted wood workers wax. Before applying the transparent colored wax I inserted aluminum foil to help illuminate the wax, similar to a cloissonne' technique used by jewelers. This is quite time consuming as there are always air bubbles to contend with which makes having to repeat the process until it looks right. The pod is then reshaped and sanded and attached to a Black Walnut shaft that I shaped to look more organic and added a Ziricote collar and spacer. The walking stick stands some 53" tall.
Unfortunately the photos don't show the bejeweled pod as brilliant as in person, as each angle shows different colors and the depth of the illumination that is magnified with the proper lighting. I will have to try photographing this in the natural sunlight.
UPDATE: Well, I've managed to take a second set of photos with additional lighting and I hope that you can get an idea of how beautiful the inlayed jeweled seed pod holes are. They are still not as vibrant in the photo as in person and the layer of CA glue I used to help prevent the wax from shattering if/when the walking stick is dropped, has created a white film which actually gives a more opalized effect to the inlayed areas.
The new owner picked this up the other day and she was quite pleased. She mentioned that the other walking stick #060 http://lumberjocks.com/projects/22478 has worked for her quite well and that even her health care professional was surprised as to how well it allowed her to walk. I must say I'm pleased that my work has given the user a sense of stability and pride in using my canes and walking sticks, as I do believe that one should feel assured of themselves so they can go out and conquer the world! Or at least get through their days with a little less hassle.
For more informaiton on my work visit: www.bigstickcanes.com
Comments and inquiries welcome.
Gallery
Comments
· Registered
That's a beautiful piece of work! I like art with a function intended. There will always be something to talk about when your client is using that.
· Registered
I think this is the first time I've seen you make this type of handle, Meilie.
Gorgeous Cane!
Lew
· Registered
WOW!!! Awesome. Beautiful work.
· Registered
Isn't that cool! Great looking design. Nice work on that, cool curves. Fun…..............
· Registered
Wow.That's really different. Nice job!
· Registered
I really like this a lot, real character, and balance of design too!!! Great job.
· Registered
Beautiful job. I like the pod and the shaping of it.
· Premium Member
Wow, beautiful work!!
· Registered
wow..totally amazing. whoda thunk it? I would love to see this one in person..it is captivating
· Registered
Wow, this IS beautiful! You've really got such an eye for these things. Looks just fine in these photos, I can't imagine how better it could look.
· In Loving Memory
One word!! AWESOME!
I wonder could you make one those handles for a gear shift? (HEMI MOPAR MAYBE)
· Registered
Actually I tried to see if I could take the gear shift off of my Murano and it's way too difficult. The guy at the dealership was all excited about it too.
· Registered
· Registered
OOOOOHHHH bedecked & bejeweled! the handle is just plain gorgeous and I'm amazed you found a pod big enough and that you could put finger slots in… IT"S SUUUUPPERB!
