Project Information
A slide show about the build:
I've shared my story and my concept in my bed post.
This table is the second piece.
As I see I rather build a piece of furniture around a beautiful piece of wood… This time no choco locust but a majestic piece of curly cherry. 18-20 inches wide and 12 feet long.
The rest of the table is also cherry. Since this piece has no artificial fasteners (glue, screw, etc), only solid wood, this table is 100.000000% cherry. When it was unfinished anyways… The finish is raw tung oil BTW.
The joinery consists of three sliding dovetails and four tusk M&T joints. To do so it needs to carefully plan the dimensions around these joints otherwise wood movement will make you finish your dinner on the floor one day… One long sliding dovetail joins the two halves of the table top and the other two joins the top to the frame. This time my hunger for accuracy was really satisfied. I loved the challenges of not making errors bigger than a few 0.001" on a span of a few feet. The first and the hardest was to edge join the two slabs. Straight edges weren't straight enough for this kind of joinery. The only way to measure straightness was to put the two edges in front of each other and measuring the gap between them with a fine feeler gauge.
Why isn't it a problem in the process of edge gluing joinery - you could ask. You don't see those tiny gaps because you use clamps to join the edges with glue and they bend to place. But for a 5 feet long sliding dovetail your edges has to be parallel to the thousandths. So I realized that I can bend a 8" wide MDF strip to dead straight and use that as a straight edge. (photo 4)
All right, I have a pair of matching edges now. Great. But if I'm going to use my router table to make the dovetailing it'll sure f…'em up. Partly because of the insufficient accuracy of my router table, partly because of the weight and poor maneuverability of those slabs.
So I have to move the router on the edge. That means I had to make a router base plate fence for my palm router. It turned out great. (See the test piece on photo 5) Now about sliding dovetailing. Two words… climb cut. Fortunately I learnt it on the test piece. (I've always been a big fan of climb cutting anyways.) The other accuracy demanding task was to make the two parallel cross cut stopped sliding dovetail groves for the rails on the back of the table top. I used the already assembled frame to be the stop blocks for the edge guides. Fast, accurate, fool proof. I think the title of the book of my dreams would be "Stop Blocks and Climb Cutting". LOL
I'd had several options for joining the legs to the frame but eventually I decided to use the well established tusk mortise and tenon joinery. The stiles sit on straight shoulders under the mortise of the legs. The mortises are slightly bigger than the tenons and the upper end of the legs are 1mm lower than the upper edge of the stiles and the shoulders of the dovetailed rails allowing the wood to move freely in any direction.
Router surfacing had always been a pain in my workshop until I fitted my sled with dust collection fixture. Aaawww, what difference this made… Like my HBDT jig with dust collection. :) In addition I've learnt that lubricating the router base plate can make wonders when it comes in contact only with a jig. I think I could've moved that router beast even with my eyelashes.
The rest of the build was about templates and stop blocks for accuracy. You can see them in the video.
The table was done two days before we got married. That day was magical. Wonderful friends make wonderful days. Let it be a wedding or hiking in the mountains or getting together in our home talking about a bunch of interesting stuff.
As I see, these pieces of furniture gather us around them. The bed became our most used couch too. We often watch movies on the bed with our friends. Fortunately the bed is rock solid loaded even with the six of us. The table became also a gathering place in our home. And that's the best part of making furniture.
Now it's time to do some cabinetry without artificial fasteners…
Thanks for reading along,
Johnny
Gallery
Comments
· Registered
A cool design,nice work.
· Registered
Nice table. I like the design and choice of materials!
· In Loving Memory
Beautiful table and I love your "all wood" joinery. Great slide show of the process. Don't think I've ever seen a top attached that way but I love it. Great job all around on this piece. Your precision is awe inspiring (LOTS of set up I assume is the answer).
· Registered
Great job it looks great!
· Registered
Fantastic table! Like the wood grain, live edge and the amazing joinery. Great build!
-www.sawblade.com
· Registered
Great challenge. Nice story. Like your theme and narritive ( philosophy) in your work. Looks like it's working for you. Oh yeah really nice piece. LOL!
· Registered
Outstanding process,beautiful table!
· Registered
Beautiful this table!
But sorry for pointing to another fact: the carpet with the flowers…. is lovely too. ;)
· Registered
Thank you guys for the kind words.
Honey: You won. Someone commented on the carpet. And that person happened to be you… You're cunning. The bet is over.
· Registered
I really like the part in your story ' I have this hunger for accuracy' Well it sure looks like that hunger was well and truly satisfied!
