Project Information
I had a few chunks of cedar on the saw from the deck we're building and decided to try one of these cube in a cube gizmos. Surprisingly fast and easy. I probably have 15 minutes in it. Cedar is not the ideal material because the center cube got a little beat up. Very easy to sand and needs no finish though. Smells darn good too.
Size is 3" x3" with a 2" hole from the forstner bit.
If I make another one, I'll use a harder wood and build a fixture to hold it tight to the table of the drill press. It got a little tough to hold with just a couple stop blocks clamped to the table.
Here's a link to Stevinmarin's project with a nice video.
http://lumberjocks.com/projects/25225
