Project Information
Problem - I have a need for a lot of sleds. I like the precision and safety of using them. The issue is they take up a lot of space. I don't have a lot of space.
The solution ONE sled with replacable zero clearance inserts. Now I get true zero clearance cuts with any blade and any cut.
I made the bottom insert 1/4" and the fence insert 1/2" since it will be taking the full height of the blade.
While this is fairly unique, I can't take credit. I combined John Nixon's supersled with an idea I saw in popular woodworking.
I added my usual incra T-Track plus, Miter fence with Incra t track, incra T-Track stops and stop blocks.
A detailed how-to instruction guide can be found here
Gallery
Comments
· Registered
Very nice looking and functional CC sled. And I agree with You that a good sled is a must have!
· Registered
Thanks. I'm sick of tripping over sleds, so I'd rather have just one that does everything. Also if you only have 1 ZCI per blade, you can trust your kerf lines for cut alignment.
· Registered
This is an awesome sled. Great instructions too. Thanks for sharing.
· Registered
nice!
· Registered
That looks like a great sled! Thanks for sharing all the pictures and instructions.
· Registered
Looks like a perfect sled for what you were setting out to accomplish. I like the replaceable zero clearance insert idea and the durable look of the jig.
· Registered
Great job, love it
· Registered
Joe,
Thank you very much Joe! I'm studying your instructions. This will be the second sled you helped me with!
· Registered
Nice sled like your details,,,, I watched a video a yr or two back on this super sled and have thought about making it. Well done should serve you well.
· Registered
Joe, about the 0 clearance insert. Would it ruin your back fence if you were to make some beveled inserts? I see lots of possibilities but I wouldn't want to compromise the alignment or stability.
· Registered
Great sled! Now all you need is an insert in the back for different angles that match difference ZCI.
· Registered
I have a lot of blank inserts for future bevel cuts.
Mark, the insert in the back fence takes the hit for the bevel cuts. I can cut at a 1" depth (with the gullets above the work piece) before I cut into the actual fence.
That is also why I chose to use 1/2" plywood instead of 1/4" plywood for the fence inserts.
· Registered
This is basically what I planned to do but with a slight modification. I think eventually you will wear out the holes where you screw down and into the bed and the fence with the sacrificial inserts. I was planning on adding either inserts or nuts into those spots and using machine screws to hold the inserts down. Thoughts?
· Registered
Top shelf!!!!!!!!!!!!!!!!!!!!!!!.................Jim
· Registered
I am a little concerned about the screw holes. I actually planned for inserts so I have enough room (and a package of inserts). I'll see how long they hold out before I need them though.
· Registered
Nicely built sled and will be a joy to use .
Like the idea of a multi purpose sled and the zero clearance inserts also allowing it to tilt and have zero clearance .
I built a sled with the same ideas in mind and came up with a double bottom design http://lumberjocks.com/projects/61820
which has worked very well for the last year and a half .
· Registered
The zero insert is a great idea Joe.
I wish you posted your sled a couple months ago :)
Oh well I will use it in rev 2.0
thanks!
