Project Information
I made this Country Table for my brother and sister-in-law. Red Oak table top, the apron is popular (which I got at the same price as select pine, because the yard was out of pine), and the legs I turned from 4X4 Douglas Fir. First time I turned any thing of this size and I copied the legs on there kitchen chairs. Lots of practice and patience (which ran a little short at times and had to walk away), but I certainly learned a lot. Painted with a gloss enamel and the top I filled the grain with diluted poly and sanded while wet, I then applied 8 coats of wipe on poly which I made by adding 50% mineral spirits and a coat of furniture wax. This is the first time I have used wipe on poly and I really liked the way it goes on, so easy to work with and very little sanding in between coats and I am happy with the results.
Gallery
Comments
· Registered
Hey Doug
Very cool table looks great. I like the contrast of the red oak and green paint. Well done.
· Registered
Nice table, clean lines and I like the found space with the drawer in the apron. Was the most walk away times related to the concave turning below the second round from the top. I have recently reactivated my lathe. That has been the hardest aspect for me to turn. The gouge has a habit of grabbing the higher material and digging. Even with a fingernail grind and careful rotation of the shaft.
Really like the table, great work.
BTKS
· Registered
Doug - Great table. I was recently approached by a family to do this exact style table for thier covered porch/outdoor room. Looks great, and very solid. Kudos on the self-turned legs!!
· Registered
Thanks guys. socalwood: I attached the top using table top fasteners from Rockler, they work great and allow for wood movement. BTKS: Most of my walkaways were when I was practicing, especially the beads. I got to where I was turning the beads to the left quite well, but the to the right was a different animal and I still have trouble with that direction. I rounded my skew using Al Lacer's method (from the Feb/Mar 2007 American Woodworker), which I think is easier to use but takes a lot of practice, just that one direction is my nemesis.
· Registered
Great work! That'll grace your brother's kitchen for years to come!
· In Loving Memory
Just perfectly proportioned and made I like the green and plain wood it goes well.Alistair
· Registered
Thanks Doug,
I've read where some guys just take old files and grind in the bead profile they want and make a job specific tool. Kind of a glorified scraper / cutter. One radius on one end, another on the other. Just an idea. I'm still having my greatest nemesis with the inside concave cuts. Good luck and good turning.
BTKS
· Registered
Very "Country" looking. Nice.
· Registered
Just stop to take a look at your table to get some ideas, I want to build a kitchen table too. Very nice job. Great looking legs. Take care.
· Registered
Love this table - basically what I'm looking at doing, maybe a more "weathered" top with some reclaimed wood. Just got into lathe work and I'm instantly obsessed :) Btw, hello from another Northern Michigander (Traverse City here!)
