Project Information
I started building this maybe 3 years ago (time flies) and finally finished it early this summer. Made from plans found in popular woodworking magazine, article by Glen D. Huey. As per the article I think this project was a great intro into building period furniture. Not too complicated as long as you take your time. I chose to build mine out of cherry for its beauty and cost.
The lowboy is dyed cherry with an antique mahogany water soluble dye. I was pretty scared after the first coat, however it evened out after two more. The final finish was a little darker than I had originally planned, though dying it rather than staining it really lets the grain show through in a very striking way. The rest is clear coated in poly, with only the top being buffed out to a high polish. I think if I had to do it again I would finish it with shellac, however there were already enough "firsts" in this project that I didn't need to add any more :D Thanks for looking
Gallery
Comments
· Registered
Wally - great job on this…really first class. The dovetails are really fantastic.
· Premium Member
Tremendous job on your low boy. I have this on my list and hope it turns out as well. Thanks for the pointers.
· Registered
That is fine.
· Registered
Beautiful job W'331.... love the dovetails.
PS. Once I tried to Connect 1 cut and missed… since then the missus has been calling me a lowboy.
· Registered
Looks great Wally I've got one myself to finish up, hope it looks as good as yours.
· Registered
Beautiful piece, well done!
· Registered
Beautiful work.
· Registered
The craftsmanship looks great and so does the finish.
As for shellac, you made a good choice. I love shellac fir some things. But this is the kind of furniture that some unthinking guest will set their alcoholic drink on and then you have a problem. So if I do ever choose shellac as the primary finish for furniture, I'd still give it a thin final coat of something more protective against alcohol.
Anyway, an impressive piece of woodworking.
· Registered
Beautiful, a classic, wonderful project and work!
· Registered
Great looking piece, wonderful workmanship.
· Registered
Real nice work! Love the detail around the drawers and the legs.
· Registered
Wow! Thanks for the comments everyone, can't believe I made daily top 3. Good thinking about the shellac Alan, after working with modern finishes for so long you forget about that sort of thing!
@aijim, looking forward to seeing the finished product!
· Registered
Beautiful! I wish the pictures were higher resolution/larger! Not your fault, LJ just keeps the photos small and hard to see all the detail.
Inspiring piece!
· Registered
Nicely done.
· Registered
There should be a masters class in lumberjocks, this would be top honors.
