Project Information
Hi Lumberjocks!! I've been so busy at work this last month so I it was impossible to me to enter to the workshop… till now.
This time I wanted to start experimenting with concrete and wood. For this project we need some pre-work doing the mold. As you can see, for the outer shape I used a cardboard tube but for the inner one I didn't find one with the needed diameter. So I used the lathe to turn a small piece of soft lumber (yellow pine) to be the inner shape of the mold.
As you will see I recommend to shake the concrete before curing to achieve a uniform piece. Otherwise you leave it without doing this to achieve a irregular shape with bubbles (you will find a picture of this in my facebook and instagram as well).
Also, you will notice I broke accidentally the concrete piece while I was unmolding it. I can assure you that after repairing it with quick concrete you will obtain a rock solid piece.
Finally, I applied clear wood wax in the whole piece to obtain a dust-free and glossy finish.
I hope this video inspires you to try new things. Please, like and share my work to help me keep doing this. Thanks.
Gallery
Comments
That is very cool. Very european.
Madts.
Thanks madts! I certainly use again concrete for further projects. Regards from Barcelona!
