Project Information
I've been needing one of these benches for a while and I found the plans in Instructables.com
It is great for so many applications such as fit it in the back of your truck for on the job, build it the same height as your tablesaw as an infeed, outfeed table, the possibilities are endless
The plans detail the entire project build and they used lap joints for most of the build I also used lag bolts to strengthen the joinery even more .. I even put t nuts into the mating pieces and nuts and washers to tighten everything together ..
Just remember to adjust the table top dimensions if you alter the height of the legs and cross brace otherwise it won't fit into the box ..
Enjoy and thanks for looking
Gallery
Comments
· Registered
Ed, do the legs get secured in the sockets once assembled if you have to pick he table up?
· Registered
- greg48
Hi Greg,
No !!but that's not a bad idea just drill a long hole through the corner into the leg and secure with a washer and nut
