Project Information
Another project complete using my thrift store score of redwood roots.
I've been trying my hand at the blog feature, there you can find more details on the build
For the condensed version, this started as a pretty nasty piece of redwood drift wood found at the most unlikely of places; a local thrift shop. The raw piece was pretty nasty, there was a good bit of punky areas to contend with, but the price was right so I decided to give it new life.
I cut the initial chunk into two with my old crosscut saw, then proceeded to use an angle grinder with a flap disc to make quick work of knocking off the weathered patina and stripping away the punky wood.
After the basic shaping I flattened to the and bottom using a router jig and finally spent a good 3 or 4 hours sanding mostly with a random orbital sander (and a bit by hand).
Finish is 3ish coats of shellac.
What is really unique about this piece is that there is no true top, bottom, front or back. It really gives you something interesting from just about any angle.
Plan for now is to try to sell this locally and turn those proceed back into the hobby. Sometimes it's hard to let go, so that plan may change..
One note, yes, my living room floor is plywood… currently in the middle of laying hardwood floors.
Gallery
Comments
· Registered
Great work. Awesome color and finish.
· Registered
beautiful work. And if you kept it, it would be a prized possession.
Don't you love the way shellac makes things pop. Poly never does what shellac does.
· Registered
Very nice.
· Registered
I am so jealous, I would go to the thrift store with my wife is they had stuff like this there. Amazing work…. What a great table.
· Registered
that is awesome, it is so cool and beautiful, great work
· Registered
That really is an amazing piece. is it two different bases, or is it just that it has so much character it seems that way? either way, it's definitely one of a kind! just for curiosity, what are the tabletop dimensions? is this coffee table size of dining table size?
· Registered
Gridlocked. It's just one base pictured in different orientations. It's coffee table sized;
Height: 19 inches (38cm)
Length: 30 inches (76cm)
Width: 22 inches (56cm)
· Registered
Very Nice! & Well Done! Thanks For Posting.
· Registered
Wonderful table! Like the gorgeous driftwood, perfect base for the glass top. Excellent work!
