Project Information
Classic red oak silverware box. Raised panel top and sides. Top compartment houses single items while drawers hold a set of 16 utensils. Lining is black Suede-Tex. Drawer sides have stopped grooves allowing drawers to slide on hardwood runners. Drawer fronts are fitted with tiny solid brass knobs. Finish is a brushed gloss polyurethane over an oil stain.
Gallery
Comments
· Registered
Beautiful. Meticulous attention to detail. As the title says, Classic!
· Registered
I really like this! great job
Did you make your own linings? if so, can you get me started on my own impending project.
Thanks for sharing!
Trev
· Registered
Heirloom piece if ever there was one!
Your great grand kids will admire your work!
· Registered
Trev said: "Did you make your own linings? if so, can you get me started on my own impending project."
The lining is Suede-Tex, which is a flocking kit I got at Lee Valley. You simply paint the inside of the box with a special paint, then spray loose fibers into the paint and wait until it dries. Similar to blown insulation for house. It is very easy to use and you get perfect results. It comes in different colours (both fibers and paint). See http://www.leevalley.com/wood/page.aspx?c=1&p=44669&cat=1,250,43298,43300.
· Registered
Looks great.
· Registered
Thanks for the tip on the flocking gun. I'd always wondered how well it worked. Sounds like a good solution.
