Showcase cover image for Clamp Rack
Comments
very useful and it doesent take up much space just what i need
thats perfect for what i need in my shop would you mind if i used your idea …........
Nice work, I made one like this as well although had 3 box's. Never enough clamps right? It helps.
Great job
It looks very well
I just need one like this
I think I will use your idea
Thanks for sharing
What size?
Clever idea, like it very much. Especially the swing out option makes this solution so spaceful. And i think it is ok without any finish.
Thank you for sharing!
jchfromnyc
Thanks a lot for the link
Have a nice day
I made one cause I thought I would get my clamps super organized. I did not use a heavy duty enough wood and the weight of all my clamps broke it. Yours looks like it will hold up much better.
Mine has too many clamps on it. It hasn't broken yet, but she's bowed pretty bad.
Has anybody ever seen any kind of racks for "C" clamps. I have a bunch of them, all different
sizes and can't figure out a good way to hang them up. Thanks.
Thanks all. SandyK - after making it and loading it, the smaller hinged shelf didn't bow, but I don't think the piano hinge can hold up to the weight. It flexes enough that there's about an inch difference in the bottom of the shelves at the right side. I put a little block of protruding wood for the shelf to rest on when closed. If I did it again, I would probably use heavy duty gate hinges, like in the plan.
