Comments
Premium Member
WOW! You really went to town on these! What was the most difficult part in production dschlic1? Thanks for sharing.
Cool blocks. Did you use 3 different size Forstner bits for these with 2 blocks inside. Can you please describe the bit and the depths you used to make the triple block?
thanks, Jim
Wow that's sure a lot of blocks, great work
Very nice ! Here's a video explaining the construction of the cube.
Video
WOW - that was a LOT of drilling!
I bet the stack of chips in front of your drill press was pretty impressive.
Great job and I'm sure every person who received one will love it.
Cheers!
-bob
The most difficult part was seperating the inner cube from the outer. I used a Dremel tool with a cutoff blade and then a carving bit. Once the inner cube was free I touched up the inside of the outer cube with a Dremel drum sander bit.
The cubes measure 3" across. The big hole was made with a 2" forstner bit and the smaller hole was 1". The depth of cut was such to leave about 1/16" to 1/32" remaining. Once set same depth was used for all.
What a great gift. Just set in on the desk at work or the counter, coffee table and let it do it's job
Great job Santa. I;-D I like them.
