Project Information
This is for an upcoming Holiday Gift Exchange at work.
It started out as a 4 layers, but laziness in gluing up the rings means I did not measure accurately and the top ring was too far off of center.
I decided to part off the top ring and see if I had enough material left to re glue. Nope, it was no go.
So I pressed ahead and finished the remaining 3 layers settling for a bowl 5 " in diameter and about 1 3/4" tall.
Here's the finished bowl with the first coat of gloss sprayed on and the top ring that was parted off.
I'm calling it a save.
Lessons Learned:
Take your time and measure, never trust your eye no matter how many times you have done something.
I don't like turning Cherry, it tears very easily. I wound up relying on my disposable 60 Grit skew to get this one done, I just could not get the tear out eliminated with a tool.
I was also experiencing a lot of chatter when working this piece. When I removed the jaws to replace with my Cole jaws I noticed that I installed the Jaws on my chuck in the wrong places jaw 2 and 3 were switched and I'm pretty sure that was the issue. Those things are indexed and labeled for a reason!
Finish is 1 application of BLO and a clear Gloss top coat.
I hope the recipient enjoys it.
Gallery
Comments
Very nice bowl and the wood grain and colour is beautiful. I am sure who ever gets it will be very happy with it.
Great job and thanks for sharing.
Did you cut the rings with the Ring Master lathe?
Nice job saving a pretty bowl.
Just got through cutting out a solid cherry bowl on my scroll saw , never again.lol. that was the hardist wood i have ever cut , except for and old fur board i made a bowl out of , i think you did a great job.
Thanks for the compliments.
Hunter, The rings were cut freehand on the lathe using my shop made thin parting tool.
My bowl from a board process is documented in this blog series
For this one I used my 4 jaw chuck and a recess drilled in the bottom center using a Forstner bit rather than a face plate.
Cutting the rings is in this specific blog entry
The secret is a thin parting tool. I made mine from and old reciprocating saw blade. Google "shop made thin parting tool" there are tons of videos and articles on this.
Handyman, I just looked up your cherry bowl project, very nice. I have never done a bowl using the scroll saw.
You do have to go slow with cherry when using power tools as it does burn easily.
The color and shine on that cherry is fantastic.
Sometimes you just have to make the save. Great job
Great job
