Project Information
With my first child due sometime within the next few weeks, I thought a change table would be a suitable project. I worked from some Ana White plans with very minor modifications to accommodate the size of our changing pad. I used pocket screws and I learned a fair bit doing this, my second project. I had to recover from a couple of errors, most notably when the screws split the wood (of course in the last joint). I ended up having to rebuild the one side of it but was pleased that it went much, much faster than the first panel I put together.
This was also the first project I've made since getting my mitre saw. It definitely made things easier-it's much more accurate for crosscuts than my cheapo table saw. I think I'll get a fair bit of mileage out of if I ever get a chance to do anything after the baby comes! It was also the first project on the workbench i built. I'm pretty happy with how well that worked out. I wish it were bigger but all I have is a small fraction of our one-car garage. I'm getting by, though.
Anyway, this is done except for the finishing. I'm debating with myself what to do. The original plan was to paint it white, but I actually think the pine looks pretty nice (especially considering it is just from Home Depot!) and am considering coating it with something. Not sure what. Any suggestions?
Gallery
Comments
The sign of a good woodworker is not that they don't make mistakes. It's how they recover from them. Nice job.
Myself I like finishing my projects with a wipe on poly. 50-50 mix of off the shelf poly and mineral spirits. Wipe on, wipe off. Repeat 5-7 times rubbing down with 0000 steel wool in between coats until you get the finish you want. I like to use semi-gloss and this approach gives you a nice glow and not a heavy built up plastic look.
It's beautiful and well made changing table. Like the simple and clean lines. It will be great in natural finish. I'm sure it will serve you well for a long time.
