Project Information
Shaper tooling has a lot of sharp edges and some of it can be quite heavy. A friend of mine told me how he made carriers for his shaper tooling. Sounded like a great idea. I cut up a piece of 1/2 inch plywood and put holes in the middle for 1 1/8 inch dowels of appropriate length and grabbed some drawer handle bulk packs from the big orange box. Rounded the corners with a router jig.
The tooling falls in roughly three different sizes, so I standardized on 3 basic sizes. Most of my tooling has a 30mm bore with a couple that have 1 1/4 inch bores, so 1 1/8 dowling works for both. Sometimes, I need to remove some of the knives, so I epoxied some magnets that hold the loose parts. Plastic feet to keep the screw heads for the handles from scratching things.
Finished with shellac.
Thanks for stopping by!
Gallery
Comments
Great idea. I was always leery of carrying my molder heads around after sharpening. I was always afraid I was going to drop one on my foot…
Do you find that your fingers are still pretty close to those sharp edges when gripping the handles?
They aren't terribly close. I didn't want to make them too big. Having the handles to hold makes them fairly easy to pick up and move. And I usually wear gloves.
All the carriers are 190mm tall. The widths are 180, 210 & 260 wide. The handles are inset 25mm from the edge. One could widen a carrier 10-20mm for more clearance.
I'm currently storing them in a 4' lateral file until I figure out a better cabinet solution.
great idea, but why didn't you recess the heads. That still makes sense. just put a small counter bore in there.
seems like even a kreg stepped bit would do at making the counterbore.
get that metal out of the way…
I thought about that, but the screws on the drawer handles are designed to go through a much thicker piece. The 1/2 inch plywood really isn't thick enough. I was only barely able to get them tightened down with a driver. I suppose one could find shorter screws and do the recess. The plastic feet were the most expedient solution.
