Showcase cover image for Built-In Dining Room Benches with Storage
Project Information
Hey everyone! It's been awhile. I just finished installing these dining room bench seats today and wanted to share. These were built in the shop, then delivered and installed. The basic construction is 3/4" sanded (cabinet, paint grade) plywood with solid Poplar for some parts such as the ledge at the top of the back support and the applied quarter-round molding around the edges of the seats.
The seats lift, using piano hinges and there's lots of storage space underneath. It's not true frame-and-panel construction - the "frames" are just 1/4" material applied to the surface of the plywood.
Sorry I didn't think to take pics with the seats lifted. The piano hinges work great though.
This was a tough install - built in two pieces to be joined at the corner after transport. The walls were everything imaginable; out of square, out of plumb, floor had some major dips. The baseboard had to be scribed along the floor and cut at a slight arch along the bottom. After a lot of shims and a bit of caulk though, it turned out great. Client's happy. I'm happy. Life is good.
Thanks for looking!
Gallery
Comments
Very good looking benches, Scott!!
Cheers. Jim
Great job very clean…..
Very Nice Work Scott!
Did you use solid Poplar for the rails and stiles? Did you use 1/4 inch plywood for the panels?
Looks clean and good use of materials keeping expenses low, I have a lot to learn in that department.
