Project Information
Pictured: A simple wooden tissue box cover. The one on the left is cherry and walnut and the one on the right is made of Padauk sapwood and White Oak with ebony corner splines. It is a 5 1/2 inch cube of 1/2 to 3/8 inch thick wood. There are others pictured of various woods. All are made to the same size and shape.
You can make these with a two foot board and a 6 inch square scrap for the top. This post also includes a how-to section and a jig for larger production runs if you are interested in that.
Story: This is a simple design and is a great starting point for developing skills used in building boxes and inserting splines. I started making these before I made boxes and now I build these with young, or beginning wood workers to get them started on the process of box making. To be honest these make great gifts, but it is difficult to make much money on these as a sale item. Customers won't pay too much for a Kleenex cover. There is some profit in them if you make them efficiently enough. However, they are really simple, easy, and fun to make with a few tips.
Techniques:
Cutting: Start with a 5 1/2 inch wide board 24 inches long, planed to 1/2 to 3/8 inches thick. Cut it into 5 1/2" lengths, and 45 each end.
Sides: Re-assemble the board as it was originally…putting the long sides up. Now, tape these segments together, turn them over, apply glue on the angles and roll up the four sides as a square taped together band clamp it tightly until the glue dries. Now you have the vertical sides made.
Top: Apply glue to the top of your sides, center the slightly oversized top on the sides so that the hole with routed edges is in the center of the sides. Tape the top in place with an x of masking tape. If you don't tape it down, the top will slide around on the glue and will move off center as you tighten down the bolt.
Clamping: Here you see a simple clamping jig for making these. It is two 5 inch squares of plywood with a hole in the center and a 6 1/2 inch long 1/2 inch nut and bolt with a washer under the nut and the head. Tighten this with a pair of wrenches, or if you are lucky enough to have one an impact drill will speed up the process. This will give you a great fit on the top joint and you won't need any other clamps. (Hint for making several of these at once: If you apply the top and light pressure on your bolt clamp before you completely tighten your band clamp around the sides, your sides will all have perfect alignment with the top. Once you have fully tightened the band clamp, fully tighten the bolt clamp. This method means you only have to wait once for all the glue to dry.)
This is a simple box made to organize the clamps, bolts, and wrenches. It sure is handy when you can just pick this up and go to work making your covers without wandering around the shop looking for things.
Final Steps: Trim the top to the sides, cut spline slots, glue in splines, round to suit your taste, final sand, then apply finish. Put at least one coat on the inside to seal the wood.
Efficient Production Runs:
What's This? This crazy looking thing is a mandrel to hold these tissue covers while you sand them. It is not worth making this for just one or two covers, but if you are going to make 6 or more of them for Christmas presents or wedding favors; it might be worth the time to make one of these and keep it on hand for future production runs. It starts with three 2×6 segments screwed together so you get a 4 1/2 inch square "post" to slide the cover onto.
How is it used? Here you see two boxes attached to the mandrel. The one on the right will hold the cover while you sand the top. Notice the plywood ends to hold the cover proud of the center so you can sand the center hole by hand. Note that there is a nut and octagonal wooden "washer" to keep the cover from sliding off the horizontal mandrel as you sand. On the bottom is a cleat that I put in the vise to hold the whole mandrel in place as I work on the covers. (Hint: If your cover rattles and is not a tight fit on the post, wrap a thin rag around the post before you slide the cover on.)
How does it help? This is where you really get a benefit from using this mandrel. There is a hinge at the back that lets you lift the post and there is a flap at the back attached to the hinge. The flap has a bolt through it into the center of the back end of the horizontal post. This means you can spin the post and put it back between the two front triangular stabilizers again. In other words you can turn the cover from side to side without removing it from the post. This makes sanding go much quicker since you have easy top access to all four sides. Since I round the sides I can sand a side, corner, and side then turn the post and the cover.
Critique and Pointers: These work well and are a super way to use up small scraps of pretty wood hanging around the shop. The weight makes it easy to pull out the tissues and they do look nicer than the cardboard boxes. There is some slight variation in box size among different brands of tissue. If your cover is too small some brands will not fit; so leave a little extra room inside. A round hole works about as well as an oval and is easier to make. Be sure to route the bottom side of your hole before assembly. If you sell or give them to others, buy a box of tissue and put it inside so you don't have to explain what it is. It is worth the money and the process goes more smoothly.
Thanks: As always thanks for looking and a special thanks to everyone in Lumber Land who takes time to make comments and suggestions. Keep boxing…keep posting and making this posting a "Top Three" is a real show of support and keeps me excited about doing things in the shop and on line. I appreciate all your support.
Gallery
Comments
· Premium Member
Nice work and nice lesson boxguy!
· Registered
Boxguy thinks outside the box doesn't he??? Nicely done…................
· Registered
Hey, Big Al
Good lookin' tissue box covers.
And a great production combo jig. - Len
· Banned
That is definitely a creative solution to blue your tissue boxes. Very Nice…!
· Registered
Nice lookin tissue box covers. I may have to make some rof my craft show in Nov. I may have to make a mandrel as well. Thanks!
· Registered
Boxguy, you make some beautiful boxes! Keep it coming! Thanks for sharing.
· Registered
Thanks to everyone. What fun to get support and feedback from Lumber Land. It is magical that some guy in a little shop in Southern Indiana can hear from fellow woodworkers from all over the country about some boxes he has made. What a wonderful age we live in.
· Registered
The tissue boxes are nicely done….but the jig!!! That's an awesome idea. Thank you!
· Registered
Very Nice Projects! Thanks for Posting!
Rick
· Registered
Wow I missed these, very nice.
· Registered
I see you have made many of these boxes. Can you tell me what you have found to be a good size hole in the top of the 2 types of tissue boxes? (Oblong and Square). I am going to make up a template but I am not sure what to use for the ellipses dimensions.
Thanks!
Kevin
· Registered
Kevin, your question about hole size is a good question. What I did was to buy the box and punch out the cardboard top and use the cardboard punch out as the pattern for my template, of course you make the hole a bit smaller so the cardboard box doesn't show.
On the round holes I used a 2 1/4 Forstner bit. Since there will be some tearout on the bottom of the hole, be sure to run the top and bottom of the hole with a 3/8 to 1/2 inch round-over router bit. If the bottom of the hole is rough the Kleenexes will not come out smoothly. The best tops seem to be 5/8 to 1/2 inches thick.
As a tip I made a rough plywood jig to cut these by making a box that was 1/2 an inch larger than the outside of the finished dimension of the Kleenex box. I then put a dado inset about 1/2 inch down from the top of the box. (It is a whole lot like the bottom of most of the boxes I build.) Into the inset I put the oval pattern for my tops. I cut a stack of 10 or so tops from random scraps so that they are a snug fit for the jig top.
Now for the pay off. You can just drop a top blank with a starter hole into the top of the jig and run your pattern cutting router bit with a with a bottom bearing around your pattern and you have a rough top ready round over and glue on. Adding a hole on one side so you can knock the blank out after you cut it helps as chips tend to get in the sides and can wedge the blank into the jig.
· Registered
These tissue boxes look very lovely. I love the soft corners :)
· Registered
Very nice boxes. I like the splined corners. I have made many boxes like these but never thought to spline the corners. I may try that. I cut the oval with my scroll saw but I like the idea of the round hole. I need to try that also. You are right these tissue box covers are not fast moving items at a sale so I embellish them with inlays or appliques. I am working on making 18 of them right now. Thanks for this post. Here are some photos of some I have sold:
· Registered
Nice boxes. Like the splines on the corners, adds interest to the box. Also like the lid glueing Clamping device. Probably faster than getting 4 to 6 clamps on the box. Also apply the force in a manner that the lid has less tendency to slide off center.
Dave
