Project Information
Hi folks,
This is a box I made as a wedding gift for a good friend.
It is made of Goncalo Alves for the sides, with a 4 corner match and finger joints. There is also a strip of Mahogany. The lid insert is made of figured black Walnut as well as the wooden hinges and finger pull.
The finish is several coats of danish oil. It's a bit hard to show on photos but it has a nice luster all over and the walnut figure looks very nice and shimmery.
The box is 11×7 inches, and I think it has a bit of an African feel.
Thanks for looking!
Gallery
Comments
Lovely indeed. Great use of very attractive wood. I really like the hinges. One of the best looking hinge designs I've seen. Well done!
Roger
Thanks!
The hinges are not what I had set out to do originally, but like mostly anything I build, they completely changed as I was making them…
David,
Looking at this box again. Hope you're going to be making some more!
Roger
Haha, thanks Roger :)
Yes, I will definitely be making more between pieces of furniture. While it can be tricky and fiddly, it requires a lot less material and so it's a lot more affordable for me.
Very nice box and a beautiful wedding gift and beautiful wood, I really like the hinges you have done on the box not seen them like that before….great job and thanks for sharing.
Cool hinges, great looking box.
What a wonderful box.
The box joints, the hinge, the woods chosen, the finish. All top notch.
Steve
Very beautiful.
Nicely done, the hinges are really cool. Great finish too!
That is fine, fine, fine.. Really like the hinges also.
A fine box. I like the finger joints and the wooden hinges are superb. Did you line the box?
The figured Walnut is exceptional.
Thanks Ruddy. It is not lined. I might try that on a future box. The bottom is Mahogany.
Very Nice Work Indeed David! Thanks For Posting!
Rick
I like this box a lot. The hinges are truly unique.
I would love to see any detail you can provide on the hinges.
Very nice.
Farrout, I did not take more detailed photos of the hinges as I had little time before packing the box.
They are made from walnut rectangles that were glued into grooves into the back of the box, after the lid was cut off. The 1/8 holes were drilled into the top portions before gluing and into the top part of the central pieces. The shapes were done carefully with a spindle sander until I was satisfied with them, getting them flush with the back of the box on each end. The central pieces were attached to the top with some brass rod. I then aligned and clamped the lid part, then folded the central pieces and glued them into the bottom part of the hinges. It had to be a tight friction fit and I used liquid hide glue for everything.
I had to make sure it was all drilled and shaped right to allow the hinge to pivot properly.
Man that is a beautiful box! I'll bet the happy couple will love it!
