Project Information
18 months ago we started to work on a Boulle clock restoration for a gentleman back east.
We received the clock piece by piece, starting with the top to show the process and what we could do to our client.
First thing was bronzes removal
The lose brass elements where lifted and then, the fish glue in the cavities was rehydrated and removed, and the back of the brass elements were scraped clean.
Missing pieces are drawned by rubbing on a termal fax paper
The missing elements are cut on brass or on pre CITES black backed tortoise shell.
Other pieces are cut
And glued down using sand bags
The cleaning is done with "eau japonaise. I do not like to use it when there is wood elements on the Boulle marquetry, as the acidic content may be to agressive and damage the wood, but in this case it is perfectly fine.
I also discovered the shell was engraved, something I have rarely seen
When eveything was restored, I used suit black to fill the brass engraving
Then the shell was re-engraved, the cavity filled with gold dust and french polished. It can be sometime tricky to french polish on brass ans the difference in temperature can bring condensation and give a milky consistence to the shellac.
The bronzes were cleaned and installed
Our client being happy with the first part, sent us the rest fairly soon after and I started working on those. The based was the first to arrive. It was the most damaged part of the clock and also the hardest to restore considering the curviness of the sides.
But also because of a lot of missing elements and details on a very tight radius part
Like for the other part, I started by removal of the bronzes, lifting of the lose brass elements and cleaning of the cavities and the back of the brass pieces.
Like for the other pieces, I cut the missing elements out of brass and shell. I harvested some of the original horn from hidden under the bronzes for this purpose.
Cleaning and reglueing using sand bags
And Cawl for the rare flat spots
Before and after cleaning the brass
I recreated the missing elements using the little informations and inspiration from the rest of the decorative elements
We ordered some missing finials in France using a picture of a similar clock
While waiting for the bronzes to be cast in France, I put the clock to the black at the same time of a decanter I was working on at the time
And gold dust was laid in the engraving
Then french polish and bronze cleaning
And finally when the finials were received, we put it back together.
The body had a tendency to lean quite a bit to the back, so I added some dicreet washers on the back horses
And substantial ebony wedges on the top
Patrick also made a new top hinge for the door to make it work very well and a new key to fit the lock.
Now, it is ready to ship!
