Project Information
Ten years ago, I was fretting over the state of my tablesaw blade storage, er, uh, there was none! I had them in a flat file drawer with sheets of cardboard to separate them. As I would swap one for a sharp one or one of a different use, I'd have to do a blade shuffle and be careful not to bang them into one another. ENOUGH!!!
I came up with this solution with three parameters in mind; it had to be portable so I could haul the blades to the sharpening service safely, it had to be made of scraps as in I couldn't use it as an excuse to buy another 100 bd' of cherry, and last but certainly not least-it had to be easy to make. I'm lazy like that.
So here's what transpired using a 4 inch wide by 48 inch strip of leftover 3/4" Baltic Birch ply, about one half sheet of 1/8" tempered hardboard, two leftover drawer bails ['cause it's heavy when it's full], an old 3" door hinge, two plastic bumpers, and the only thing I actually had to purchase was the hasp and I think it beat up a two dollar bill.
I cut four equal length pieces of the Birch ply then mitered the ends and grooved them to accept the hardboard. There are eight pieces of hardboard apx. 11 inches square. I used slow set West Systems epoxy in order to have enough open time to pull this puzzle together and get it all into a pair of Bessey band clamps. Obviously I only applied glue to three sides. After that, it was a matter of installing the hardware after a coat of poly. I knew I got it right when my sharpener said, "Wow, I like that."
It would be an easy enough design to expand in order for it to hold more blades, but as it is, when it's toting 7 blades it tips the bathroom scale at over twenty pounds. A more comfortable handle would be nice too, maybe a leather chest handle… and maybe some nice brass corners… naaaa. Anyway, I made the parts double so if I expand the blade collection much more I can slap one of these together in an hour and be using it by tomorrow.
To dispense a blade is simplicity in itself; you tilt the box forward on the knuckle of the hinge while holding your other hand across the open front, when the blades roll forward it is easy to see which one you're after and putting a finger on it, relax the box back and the rest roll back into the box. Sweet.
Here's a closer look at some of the details…
http://i252.photobucket.com/albums/hh20/jcees_photos/Blade%20Box/IMG_0014.jpg
http://i252.photobucket.com/albums/hh20/jcees_photos/Blade%20Box/IMG_0016.jpg
http://i252.photobucket.com/albums/hh20/jcees_photos/Blade%20Box/IMG_0009.jpg
http://i252.photobucket.com/albums/hh20/jcees_photos/Blade%20Box/IMG_0007.jpg
http://i252.photobucket.com/albums/hh20/jcees_photos/Blade%20Box/IMG_0006.jpg
http://i252.photobucket.com/albums/hh20/jcees_photos/Blade%20Box/IMG_0005.jpg
http://i252.photobucket.com/albums/hh20/jcees_photos/Blade%20Box/IMG_0003.jpg
Gallery
Comments
Form follows function….....looks great, and easy to store!
Nice idea. I think I might have to make one for myself. My dado could use a better case then the one it came it. Maybe some variation of what you have here.
Jcees,
Sorry to butt in, I just wanted to thank Blake, I did not know about the ! when posting photos.
Great blade holder, thanks for sharing
Jcees,
This is a very practical solution to a common problem. And is is another reason why we don't toss cutoffs. For less than two dollars you have a nice blade box.
Thanks for the post.
And with the weight of all those blades he gets some exercise as well LOL
Very nice design and construction, thamls for the post.
Good idea! And good use of scrap wood
Now that's a beauty! Great idea.
In Loving Memory
That's pretty cool! I am going to need something for my blades pretty soon.
Jcees,
Great idea for a problem alm ost all have. I will scale it down for my dado blades set! I am tired of the cardboard box and plastic edge guards!
Thanks for the post!
God Bless,
Hawg
Thanks all. Don't we all love a simple useful thing! Joshua and Hawg, I think I saw a dado holder plan a while back. If I cam find it, I'll forward it to both of you as I need to do the same.
always,
J.C.
Nice saw blade holder. Very clever use of available materials.
Your elegantly simple design, well-executed and documented construction, and recycled parts will force me into the copycat mode this weekend. Thanks for your work.
great design, another I will have to attempt.
Great way to protect and transport your blades
