Project Information
This was the last comission finished before 15 days holiday. The only interest, its simplicity and beautiful texture apart, is the way I built the drawer: the client insisted in a single big one, so I put the wheels under the drawer itself. With this solution, no worry about overturning the case when fully loaded and extracted, nor about stressed guides. The wheels are hidden under the drawer. Pachiloba wood (vitakola). Dimensions: 85 cm wide, 45 cm high and 55 cm deep.
Gallery
Comments
WOW! this is cool… what are the dimensions?
85 cm wide, 45 cm high and 55 cm depth.
Very nice design and wood.
very nice! Great job on the design changes with the wheels…
That is a clever solution using the wheels. The grain pattern on the top is gorgeous. Nice design and execution. Thanks for sharing Alejandro.
Alejandro,
Very nice work sir! I have not seen that wood before; the grain is quite striking….
Welcome to lumberjocks
Beautiful example of your work
Las correderas son de madera?
Thank you much everybody. Yes, the guides are of wood and it work just in two planes, not in the vertical one. Si, las guías son de madera y trabajan solo en dos planos, no en el vertical, para evitar precisamente el deterioro de estas.
Great job!
Thanks for the post
Callum
I like the traditional drawer glides , did you wax them ?
No POPSHOP: I use solid soap, a local? traditional solution. Have you hear something similar?
WOW! This looks awesome. I need to build something similar, thanks for the wheels under the drawer trick, I probably would'nt have thought about that until the unit tipped over on me.
