Showcase cover image for Bent Joiner's and Carver's Mallets - Mallet Swap 2019
Project Information
For the 2019 mallet swap, I was able to turn out a coupel mallets. Sorry, won't happen again…
The carver's mallet was all turned out of one round blank, and I tried to contour the handle so that it was comfortable and easy to register when used in two positions (choked up and towards the end). The joiner's mallet is a 3 piece laimnation of maple, making sure that there were no seams where I wanted to put the handle. The handle is bocote, and I turned it round, then flattened the two sides that run parallel to the mallet head to help with registration. I turned the mallet head 3 times with 3 different work axes to achieve the angles. This was a first for me, and I won't lie, this mallet almost didn't make it in to the swap… I very much like the joiners mallet
Both are finished with Natural Watco Danish Oil for easy maintenance.
These went to RichBolduc
Gallery
Comments
Wait! No pics of the joiner mallet on the lathe! Mos, that's the one (or three) pic we are all wanting to see. We all know how to hold a mallet (well..not all)!
But great job, anyway. Care to share your finishing technique for the carvers mallet. I'm still very much learning and it looks really nicely done.
JD
Very nice work. Sounds like a lot of effort on the lathe doing things I don't know how to do. End result looks great!!
The head looks like it is angled. I assume that isn't an optical illusion and was the reason for all of the axis changes on the lathe?
Super Moderator
Thanks guys!
Wait! No pics of the joiner mallet on the lathe! Mos, that s the one (or three) pic we are all wanting to see. We all know how to hold a mallet (well..not all)!
But great job, anyway. Care to share your finishing technique for the carvers mallet. I m still very much learning and it looks really nicely done.
JD
- JD77
haha, I know, when I was going through my pictures I was disappointed I didn't have any on the lathe lol I guess I fell in to the "zone" :-D
For finishing, I just kept it on the lathe and sanded up to 320 grit, then parted it off the lathe, and sanded off the little nubs with a small disc sander, and then applied the danish oil with a rag and let it cure up. I found a while ago that if I take it all the way up to 600 or 800 grit, it starts to not feel as "soft" to me anymore. Not quite sure how to describe it, but I like 220 or 320 for things I'm going to hold. I always include pictures of holding them for scale :p
Very nice work. Sounds like a lot of effort on the lathe doing things I don t know how to do. End result looks great!!
The head looks like it is angled. I assume that isn t an optical illusion and was the reason for all of the axis changes on the lathe?
- EarlS
You are correct Earl, basically you turn the blank right through the center to turn the middle part where the handle goes through, then I offset the drive center and live center 1/2" in opposite directions, turned one mallet head, and then offset them 1/2" the other direction and turned the other mallet head. It's subtle, but just enough to make it feel right in use. If I were to make another I'll be sure to get pictures and/or video
Superb, Very Nice work and great swap items.
Excellent
Regards
Anthm
Mos, that off center turning had to be a trick. You pulled it off though. Excellent and creative work!
Awesome Mos! Quality as usual! Looks like a fun build for sure.
Mos,
Love that off-center turning and that carving mallet is a great size (I'm using an old wooden rolling pin with one of the handles cut off so I probably need to get off my butt and make myself a real mallet one of these days!)
Great project - I was wondering how you did the bend. Thought maybe it was glued sections but Now I can see where a mutli-center turning was the answer
Nice job Mos, both are pretty sweet!
This is some great stuff Mos! I love the joiners mallet. Gonna have to give that one a go :)
Nice tools, mos. Both look like great mallets.
Premium Member
first bent mallet i have ever seen totally kewl idea GREAT JOB :<)) GRATZ TOP 3
Super Moderator
Thanks Tony, I certainly can't take credit for the idea, I got one from the very first mallet swap we ever did on LJ :)
Very useful whackers Mos. Well done sir!
