Comments
Very dream-like. It can imagine it as a stop-motion animation model.
Spectacular! I've never used a lathe before, so when you say you turned it, I have a bit of trouble picturing the process (which is part of the appeal). Would you mind describing it briefly?
Thanks for the nice comments. >Vakman. I'm not sure how much of the process of lathe turning you would like to know. The wood is mounted on a faceplace and the motor of the lathe spins it at a selected speed. A tool comprised of a handle and sharpened metal is placed on a rest adjacent to the spinning piece of wood and eased into it to begin taking off wood and shaping it into the desired form. In the case of this project, I spent a lot of time cutting wood into small pieces with a miter saw and then glueing them into rings, which were then glued into a stack before being place on the lathe and turned. (some of the rings were turned individually and then shaped with a disc sander in order to create the bend in the tail) It's an involved, but very rewarding process. If you would like to know more about segmented turning, I would recommend Malcolm Tibbets website. He is considered by many to be the best of the best. Viewing his work is what got me started in segmented turning.
Wow. Thanks for sharing.
This is beautiful! Well done!
Is it hollow?
Nice….very creative
I wondered how you put the bend in the tail. Beautiful work by the way!
I haven't done anything to compare to that but I have used my lathe to get some offset results before. I put a 4 jaw chuck on my lathe and after turning the main body of the work piece, I rechucked it up offset for eccentric turning or turning an axis on a different line from the center-line of the work piece.
Thanks for the explanation and referring me to Tibbetts' work, amazing stuff.
Very cool a unique work of Art.
