Project Information
They always say good, fast and cheap: Pick two. Well I think this bench has all three. I am sharing here in case someone is approaching a similar project and is looking for ways to make a great bench for not too much time or cash. All in is about $350 for vise parts and lumber. So about $350 and a weekend and you are good to go.
Many more images are here, as well as steps that are implied.
In short, I used Southern Yellow Pine (recommended in the holy grail of bench books) as durable, hard, inexpensive and obtainable. Buy larger boards in the structural section of the big box store and rip out parts that are clear. Once ripped, they were jointed and planned as normal lumber.
The top is laminated in two sections. The "field" is one big chuck and the smaller front section that will feature a tail vise and dog holes is a second section. This allows you to mill and work the smaller section independently.
The basis is a simple frame of glue-laminated posts and stretchers, with large stub tenons made on the posts during the glue up. Tenons on the stretchers are cut on the table saw then mortises are hand cut on the legs.
Mortise locations are marked on the monster top based on measurements, but it is fitted to the legs to verify. Once marked, they are hand cut as well with a good bit of help form a drill bit and/or router. Make them at least big enough as you don't want to put the top on and off many times to test.
Once the top was glued onto the legs, the flattening process is a good workout. I did a few passes with a scrub plane, then a joiner ending in a smoother. It really is only 45 minutes or work. You could do the top in smaller sections and pass them through your planner, but I really don't want to abuse my planner that way and don't mind hand work.
I had some scrap ash and cherry that I used to make vise chops and end piece to hold the tail vise assembly. The end piece is simply held on with a spline joint. The tail vise is sort of a kludge but works surprisingly well. Each vise is about as cheap as you can find. No, they are not quick release. Just turn them.
The front vise chop is long…way longer than recommended, but I wanted the room and I use a block to fight vise rack and am very satisfied. The bench side chop is bolted on so it can be swapped out in the future.
After assembly each joint was double pegged for extra strength in the event that there is any movement during drying (construction lumber is wet stuff).
The bench has proven to be worth the time and cost as it is the perfect work holding tool for hand work and power tool work.
Hand work holding:
Power tool work holding:
Not only did it make doing hand work so much more effective and efficient, I was stunned at the speed that it gave to power tool setups, especially routing.
As an aside, the holdfasts are from here and are perfect. My bench top is 4.5" and they hold well. You have to sand them when new….sand rotating around the rod, not up and down.
I think some folks get hung up on the details of a bench. First it has to exist, i.e. any bench is better than no bench, second, it simply needs to hold work. It is a big elaborate clamp. It doesn't need to hold tools, or lights, or flowers for that matter. Make something solid, massive and with enough work holding capacity that you can move on to the work at hand. This is the best time in woodworking to use the KISS principle.
Changes I may make: I may ditch the tail vise for a front vise on the end with dog holes in the chop. I have room for a deadman and plan on putting one in when needed. Right now I don't have a need - dog holes in the legs have worked well. I will put some additional dog holes in the bench field at some point.
Front Vise $100
Tail Vise $40
Lumber $180
Holdfasts $40
Gallery
Comments
· Registered
I like this! Mine is good enough but if/when I have space/need for a new one, I hope to remember this approach.
· Registered
Awesome job on this. It should last you a lifetime. I love how you hand-planed it flat. Overall the project shows excellent craftsmanship in both machine and hand tool skills. Are the rails joined to the legs with mortise and tenon joints? Thanks for sharing this.
· Registered
Just when I finally feel ok with my old junk table, I see this…looks like I've got a spring project!
· Registered
- TWegs
Yes. The stretchers have some very large tenons going into the legs, then pegged.
· Registered
Terrific build!
· Registered
Well thought out approach to the bench build. I'll agree with most of your approach except the exclusion of a leg vise. I do have a face vise in the end vise position and it works well.
Nice build, should be a good place to work.
· Registered
Really nice. looks quite similar to mine. (But yours is better)
There's something really rewarding about having a good bench to work on.
· Banned
a good well built bench can last a lifetime,so it pays to do it right the first time.yours looks like it will stand the test of time.love the tutorial you made should really help someone wanting the same kind of bench.nice job.
· Registered
I ll agree with most of your approach except the exclusion of a leg vise.
Agree but the hardware for a decent leg vise is more than the entire bench cost. I can convert it one day as the bench side chip is flush with the leg.
· Registered
- BlueRidgeDog
Depends on what you consider 'decent.'
$25 for a used (but entirely serviceable) leg vise screw is good, fast and cheap.
And I'll add this: I'm amused at the numbers of ways there are to get around simply setting a pin at the base of a leg vise. It's so easy, even a cave man can do it. But there's criss crosses, wedges, chain drives, etc. (all at their own $ figure) out there to eliminate the simple requirement to pull and re-insert a pin. It's not even needed that often at my bench.
· Registered
- Smitty_Cabinetshop
I have been keeping an eye out for a chunk of acme threaded steel.
· Registered
Great looking bench BR Dog. I'll have to agree with comments on a leg vise. I teetered back and forth between a face vise and a leg vise and ended up doing a leg vise using the Lee Valley tailvise screw. Never realized what a beast a leg vise was until I had one :) I'm with Smitty on a simple parallel guide with a pin too. All the fancy hardware is nice but putting a pin in and out suits me fine. A simple roller on the back side keeps it sliding in and out smoothly.
I like your wagon vise design. Simple, cheap and effective. I may end up ditching my end vise in favor of a wagon before all's said and done. Thanks for posting!
· Registered
I agree with Smitty. You can find screws and nuts at flea markets and the like. I chose to buy a Lake Erie screw and Benchcrafted criss cross and bench bolts. I knew at some time I would be moving And i wanted a simple breakdown set up.
· Registered
I think I have you beat on the cheap front:
- jonah
Indeed. I can't do under bench storage…I sit at mine A LOT and my legs go there!
My bench is over 200 pounds, so it is a fantastic thing that simply never ever moves when I am using it.
· Registered
The thought of moving again sends chills up my spine. I could barely get this across the shop and it certainly won't go out the door. I think I have the house I will expire in, at least that is what I keep telling everyone. When I get too old for the steps that go down to the shop I will walk the side yard, then when I can't do that, I will have some young bucks move my bed down to the shop!
· Registered
I intentionally made mine knockdown. The long stretchers unbolt from the end assemblies and the top is just lag screwed to the leg assemblies with elongated holes.
It's survived one move already and it's as solid as ever. After the move, I replaced the doors with a set of six drawers, so now I have room for all my planes (except the #7 and #8), sharpening supplies, layout tools, chisels, et cetera in the drawers. I rarely sit at my bench though.
· Registered
We paid young buck to move everything this time! The bench weighs somewhere between 350 to 450 lbs, a buddy and I couldn't even get the top out of the cellar.
· Premium Member
Great build pics in your link. Thanks for the very details. I have one on my build list this year. Great job !
· Registered
Great looking bench, I can see why you love being in your shop!
