Project Information
This is real easy to move around the shop, & its real sturdy.
I welded this up some time ago. I'd like to share this, & it's real easy to build.
Only a few welds, & its done. This stand could be used on a multitude of different tools.
If you want to make one like this, all you need is an arc welder.
Then take trip to your local scrap iron yard, or welding shop.
Welding shops usually have a pile of cut offs, about the same as as woodworking shops do.
I found some 3" x 3" square tubing with 1/4" thickness, 1/8" is plenty strong.
A piece of 1/4" thick decking for bolting down the sander.
I found some old 4" casters for wheels,
& two 1/2" x 2" carriage bolts for the leg levelers.
Just weld everything into the same configuration as my stand.
The sander is just a cheapo from harbor freight, but it has given me many years of good service.
This is the dust collector attachment I made out of a 4" plastic Tee.
A close up of wheels, & adjustable 1/2" carriage bolts into threaded holes.
Gallery
Comments
Thanks Rick!
In Loving Memory
Great idea & good space saver Dick.
Great Dick.
Thanks Guys!
I like the dust collection system! What is the make of your sander?
It's just a cheapo from harbor freight, but it has given me many years of good service.
An excellent trolley for moving various things and really easy to build. I have not understood the use of two carriage bolts for the leg levelers
Sharad
Thanks Sharad,
I just added a close up view of the bottom, showing the adjusting screws.
Hi Dick;
You are most creative!
No wonder Barb stayed with you for so long. LOL
Great idea.
Thanks Lee!
I've got her brain washed, I guess.<:O)#
I missed you this week, you must be out earning a living.
I desperately need a stationary sander. I clamp my beltsander to my workbench all the time. Maybe I will use this plan!
Thanks Christopher, your welcome to it.
good job
Dick, nice design. I wish I could weld! Thanks for the idea on the dust collection; I'm resurrecting an old Sears 6 inch belt sander from a box of parts, and the dust hood is missing. I never thought to use DVW.
Thank you Jim!
glasseyes, Thanks, & I'm glad it will help with your dust problem.
