Comments
I like that one a lot, Tim Wish you would have included the dimensions
Nice Job!
My arts and crafts style reproduction lamp project is here.
thanks
Wonderful. And yes, the new bulbs make things easier.
Gary-dimensions are roughly 13.5" high x 9.5" wide x 7" deep.
Cool looking lamp ,very nice work.
Very nicely done-I like your design.
Nice. Very simple design but, at the same time, attractive. Thanks for sharing and the pix. Good idea on the low heat light bulb.
Fits the style perfectly, nicely done.
Would you mind posting a photo of the bottom?
Tim, I added your lamp to my favorites. Thank you for sharing. :)
Great job
its like a mini door… is it all solid or did you build the panels like an actual door?
Banned
Looks kinda like the T.A.R.D.I.S. Nice job !
Tim.. thanks for the info
That is really a nice piece. Beautiful wood.
Ben-lamp is rail and stile construction. I used a combination of router and table saw, depending on what was going to work best.
WoodJitzu-I do not have a photo of the bottom, but I can describe it. Top is fastened, so the light fixture is maintained from underneath. In other words, the entire light fixture can be removed from the piece. I went simple. The fixture is fastened to an oak cutout the fits the bottom precisely, with some wiggle room for expansion. I drilled two holes on the inside bottom of lamp rail, which then receive a round mini deadbolt latch (2). The two latches secure fixture to the piece. Light bulbs are very easy to change, as you simply release the two latches and the fixture pulls from the bottom. I hope that helps.
Thanks everyone for all the comments.
Timber4fun
I just love your lamp.
In fact I love it so much I am attempting to copy your style but put a computer in it instead.
It will need to be a little fatter but I hope it doesn't destroy the look, it is just so nice.
Hope you don't mind.
Here's where I'm at right now.
