Project Information
These are a couple of special order tile frames made for Laura Reutter of Ravenstone Tiles. Made of quarter sawn white oak with true mortise and tennon pegged construction. I ebonized and pillowed the 1/4" pegs. The tiles pictured are the tiles that will be installed in the frames when the customer receives them. The tiles are 4" x 12". The plywood back has been painted flat black so when the tile is installed it will blend with the edges of the tiles.
I updated the pictures to show the tiles mounted in the frames. Ravenstone Tiles took the last two pictures after she got the tiles mounted.
Gallery
Comments
· Registered
@Oldsaxon, Thank you for the compliment, it is much appreciated.
· Registered
nice work as always MAX, you are living the dream
· Registered
Thanks Dan, I appreciate the kind words.
· Registered
Another winner Max great job.
· Registered
Great looking frames, and your finish is absolutely outstanding. If you didn't actually fume it, how did you get that beautiful finish
· Registered
@Jim, thank you.
@HillbillyShooter, Thank you for you compliment. I did not fume the frames. The finish is a water based dye, then a oil stain and then lacquer.
· Registered
Max: Great job on the frames. I truly admire your arts and crafts projects. You have the gift. Great to see a posting from you.
· Registered
@John, I appreciate the compliment, it means a lot coming from you.
· Registered
Excellent as always.
· Registered
@John Muir, Thanks…
· Registered
Really gr8 lookin frames. I also really like the finish on these. Very awesome
· Registered
@Roger, Thank you for your kind words, I really appreciate them…
· Registered
Very Nice Work Indeed! Thanks For Sharing.
Rick
· Registered
@Rick, I appreciate the compliment.
· Registered
Thanks Paul I appreciate the compliment.
· Registered
nice work
· Registered
Rustic, Thank you for your compliment.
