Project Information
This vanity was a commission. It's walnut burl veneer, walnut, and holly inserts. The mirror swivels. The mirror support was made from thin strips glued around a form. The 2 drawers on the lower right are actually 1 drawer with a slot so they would look balanced on both sides. The burl figure is spectacular and really makes the piece. The finish is wipe on oil/poly blend. You can't really use lacquer on a vanity because some cosmetics have alcohol bases and the alcohol will dissolve lacquer. See more at alancarterstudio.com.
Gallery
Comments
· Registered
I love this piece, beautiful.
· Registered
That is some beautiful figure in that burl. Not my style either, but that's a nicely done piece of furniture.
· In Loving Memory
That's a great looking vanity! The veneer is outstanding.
· Registered
What an awesome piece! I really liked your wine cabinet and the Bubinga bowfront hall table as well. Keep up the good work.
· Registered
Hi Alan,
The vanity is simply beautiful and the veneer is, as you say, spectacular. Nice choice of topcoat as well.
Thanks for the post.
· Registered
Speechless - that's beautiful!
· Registered
This is simply unbelievable! both the form and the veneer layup on this are perfect!
· Registered
Wow, wow, wow….. wow again! Thank you so much for sharing!
· Registered
Fan-damn-tastic! Lovely work. Even though the missus hates it, Deco is one of my favs. Oh well, at least she has good taste in husbands. HA!
Keep up the good work, Alan.
always,
J.C.
· Registered
YOW. That is very nice. You got skills. Thanks for showing.
· Registered
Whoa!! again just excellent work
· Registered
This is a great looking vanity. I really like this one. Wow, what a great job. Someday I hope to build things like this. Very nice, wow!!!!!!!!!!!
· Registered
hello alan C is very a beautiful piece congratulation very beautiful work
· Registered
hello alan would be it possible D to have more details on the vanity thank you and very good week end
· Registered
Hi Jeanmarc,
Actually the construction was pretty straight forward. I used birch plywood for the body, veneering over it where needed. The lower part of the top, below the step, is an open walnut frame and the top was screwed to it from underneath. Drawers were blind dovetail construction boxes with veneered fronts added. Handles are walnut dowels with holly caps. Legs were rabbetted to fit over edges of the carcase. The holly diamond was about 1/16th in. thick, set into a routed opening. Key point- no sanding of veneer until everything is in place and glued down. Otherwise you end up sanding some areas twice and can sand through- believe me, I found out the hard way on another project.
The mirror frame is 4 pieces, held together with glue and biscuits. It was rough cut on a band saw and finished with a router in a circle cutter fixture. The whole thing was held in place on a backer board until both inside and outside were routed. Tricky.
Hope this helps.
· Registered
thank you very much for the information
