Project Information
I will show my original style chess board next time. These boards were an attempt to make a board with out the ornamentation on all sides that my original boards had. These, like my original boards, have what I call a "4 triangle square". One of the first shows that I did, I had an older man come up to the booth and get right down to them and look them over real close, then he came up to me and said "Son, I can tell you an easier way to make a chess square". I said back to him "That may be, but it wouldn't be near as pretty". And I still believe that.
With this way of doing it, with some kinds of wood, you can match up the grain as it goes around in a square. It doesn't always match up perfectly, but some will. Some will until you sand it then some of the grain will go one way and some the other. At one show I had a girl ask me how I "got the end grain to go around in a square instead of round". It takes all kinds.
The three pictures I have at the top, and the first one below has this description. This chess board is 12" square, 12 ½" X 17 ½" over all. Each square is 1 ½" and is made using 4 triangles. Three kinds of wood are on the chess board. The dark square is "Elm"; the light square is "Ash", "Walnut" is around the chessboard, all from Missouri. There are 418 pieces in the over lay;
Cbd 12X18 Elm-Ash-Wal 1
This next chess board uses Walnut, Oak and Bubinga;
Cbd 12X18 Wal-Oak-Bub
The third chess board has Wenge, Ash and Oak;
Cbd 12X18 Wenge-Ash-Oak 1
The forth chess board has Hackberry, Bubinga and Elm;
Cbd 12X18 HB-Bub-Elm
And this last chess board has Wenge, Hedge and Purple Heart;
Cbd 12X18 Wenge-Hedge-PH
Thank you for looking,
Robin Tucker
Gallery
Comments
So much work and the results speak for themselves : )
Great chess boards.
I have a chess set thet I made, that needs a good board.
Thanks for sharing.
Terry
Cold Idaho
WOW , truly STUNNING work and very unique.
You are awesome man. So many ideas put to form. Keep it up , they are all beautiful and it looks like there's no limit to your ideas or energy.
it looked like the squares had depth at first, in the smaller pix. like that effect with the wenge!
