Showcase cover image for Another headboard
Project Information
My son wanted a headboard for a spare bedroom and this= is the design he chose, but he wanted the finish to match the night stands I did for him. I omitted the inlay because dark inlay would not have been visible and light inlay is virtually impossible to do on a piece that will be stained.
I made the 4" square legs by cutting stock for the 2 side pieces 4" wide (0.75" thick) and the opposite 2 sides were 2.5" wide. Then I cut the corners off at 45* to hide the joints. I also cut grooves in the pieces and added splines to hold everything in the proper place until the glue set. The leg caps are two pieces cut to the octagonal shape and glued together. I used 2 dowel pins in each one to hold the caps in place. The legs are attached to the rails with floating tenons.
The panels are solid wood and are held between the rails by loose splines so the panels can expand and contract with humidity changes. I used 1/4" dowel pins to hold the spindles.
The finish is a combination of TransTint dyes with 2 coats of Target's EM6000 sprayed on. I will be happy to answer any questions and thanks for looking.
Gallery
Comments
I'd say you nailed it. Looks like something right out of the old Stickley catalog. Did he want a footboard too?
Nice project. You're an old hand at bedsets now! Love that dark finish.
Thank you both. Earl, he decided against a foot board for now, but I can always make one if he changes his mind. :)
Nice craftsmanship Art, I'd call it bed-azzling 8^)
You say you used floating tenons for the rail-headboard connection. Are they tightened with any hardware (i.e draw bolts) or just secured with the equivalence of pins?
Very nice Art, your ahead of me on a Bed frame, I'm getting sidetracked with smaller pieces.
Hi Art,
That is one awesome head board …
A tip on doing a light inlay on a stained piece, Yeah it's tough, but it can be done with some practice … Stain the piece as normal, before the finish, rout the inlay negative and using a caliper check the depth and thickness of the inlay … install the glue making the top of the inlay a hair proud and cover with wax paper then place a platen and lots of weight. (I use gallon jugs filled with sand or clamps).
No sanding here to make it fit, that will screw up the stain … play with that on some scrap wood.
Hey Splint, I always look forward to your witticisms. :) I only used TB3 in good fitting mortises.
Doug, I would rather make smaller pieces. I could hardly carry this and it had to be glued up on site because it was too big to fit in my truck without taking the cap off.
Mike, now you tell me. haha I will try this next time, but using a router on a mostly finished piece is scary.
Ok, I was thinking the bed rails (head board to foot board). Gluing those on would make moving a bit tedious!
You are referring to the top/bottom rails on the HB joining to the legs (I assume/hope 8^)
Splint, yes, the head board rails to the legs. There aren't any side rails because it is a Purple mattress on one of their platforms.
As always Art well done. Very clean.
Thank you, Clammy. I used Dark Walnut:Reddish Brown:water in the ratio of 1:1:29.
I have a question…"How come your so damn good at your projects? I am going to have to step up my game man! :)
Great job my friend, I have figure out how to start spaying my projects. Keep up the good work!
Steve, thank you! Just remember that poor pic taking ability can hide a multitude of woodworking sins. :D
Spraying is easy. All you need is a compressor, a fan and a spray gun. Then practice with water on sheets of cardboard. I also liked Jeff Jewitt's book Spray Finishing.
Very tastefully done, Art! I really like this piece.
Scott
Premium Member
Beautiful work! I've been commissioned (by my wife) to build a headboard and I think I will borrow some of your construction ideas when I finally get my act together. This one is going into my favorites.
great looking headboard. I may be needing to build one shortly and I will certainly refer back to yours for inspiration.
