Project Information
I've seen several of these posted lately and after seeing some posted by JBWoodWorks I got the urge to try my hand at it. Sorry about the clarity of the photos, I will try to improve in the future, as well as improving my scoops, I should have made the scoop portion quite a bit thinner - next time I will get it right. I suspect that I will try my hand at these scoops again - should make great Christmas gifts.
Gallery
Comments
Nice job, Bill. I agree… these would make good gifts.
Thanks Charlie - I do see plenty of room for improvement. I have to make the walls thinner and I will remove that hole in the bottom left by the Forestner bit next time. But like any "first born" I like this one and will use it for my coffee.
Hint: If you do not want to have the "pimple" - the result of using a forstner bit, then use two forstner drills, with the second bit grind the forstner spike down to the level of the cutting blades, that way you will have a smooth finish.
Looks like you've got the scoop , looks good
What works even better is to use a half round router bit (1 1/2") and use it in your drill press at high speed and drill as deep as you need the scoop and cut away the excess. Fun to make aren't they?
Thanks Tony and Erwin - great ideas. Yes, Jim, I've got the scoop :)) Wonder what a 1 1/2" half round router bit would cost?
About 35 bucks at Woodcraft, probably cheaper on Ebay.
Now you are ready to make an expresso tamper to match the spoon
I like this one. Is there a specific amount of coffee it should hold or does it vary by person(or coffee brand)?
Rance, I'm not sure of the amount of coffee it actually holds - I have a plastic one that we have used for years, 4 scoops per pot. I made this one the exact same size as the plastic one - 1 1/2" wide x 1" deep. Works great!
Thanks Bill.
