Project Information
Dec 16, 2013
While building my rocker, I needed to make angle tenons. I searched the internet and found one that I thought would work for me so I built it to cut my angle tenons
The jig straddles the table saw fence.
The piece on which the tenon will be cut was cut long enough to allow for the tenon. Once I determined the angle needed, the ends of the piece was cut at that angle on the miter saw. In this case it was 6.5 degrees.
The movable face on the jig was set to match that angle. A back stop was added perpendicular to the table saw surface to support the piece. It could have been screwed to the face but I decided to just clamp it in place.
NOTE: The back stop can also be set at an angle to make compound angle tenons.
The blade height was also set to the right depth of cut.
The piece that receives the tenon was clamped to the face and the first cheek cut was made.
A spacer that was the width of the tenon plus the thickness of the blade was then placed behind the piece with the tenon and then reclamped to the jig and the second cheek cut was made.
The shoulders were cut with a hand saw.
The tenons came out perfect. This jig made angle tenons a snap.
If you would like to make a jig like this go to this link to get the details and plans on how to build it.
It took me about one afternoon to build the jig.
Hope this helps other LJ's building furniture that require angle tenons.
All comments encouraged and appreciated. Questions are welcomed.
