Project Information
So, about two weeks ago, I heard of these 'bentwood rings'... and, even though I had no idea what they were, or how to make them, I figured I would do a few minutes of research, and try my hand at it.
Well, I've been practicing a bit, and these are the first three that I'm decently pleased with (they took about 3 evenings, after work).
They're all ambrosia maple, just with varying degrees of color. The finish is two coats of tung, and a quick buff with my micro meshes.
These were made with no tools, none; just a dowel rod and some sand paper… which, frankly, I think is pretty cool.
They're between ring size 7 - 9 (they were sized for a few friends), and they're between 2 - 4mm wide.
Generally, I've been trying to keep the thickness to no more than 2mm, just for comfortability between your fingers.
Off to more practice!
Gallery
Comments
Nice rings!
Any chance we could get a blog or description of the process?
What kind of glue did you use?
Is it a long scarf joint to join the ends?
Thanks for sharing
Scott
well done - puts my lathe made ones to shame! maybe i'll have to give this technique a try… hints?
Sweet. Really sweet.
But quite on the build details.
Blog please.
Steve
Very nicely done - I believe I see a taper - How did you slice the thin strips needed? Also did you use heat or steam to make the wood more pliable?
Thanks for sharing
SASmith - Thanks! Pretty much everyone has been asking for a blog on these, so, once I get a little more proficient I'll try to put something together!
gvajcner - You should definitely give these a shot, they're kinda time consuming… but they're fun, and rather pretty.
SPalm - Thanks, as always :) There are still a few things I need to figure out, and then I'll try to break the cone of silence on these things. It's weird how little info there is on how to make them.
SgtSnafu - With an X-acto knife… and I used heat and steam to get the wood more cooperative.
Look up my buddy Rance. He is quite clever and sometimes witty
He's done a lot of these and posted info. I'm sure he'd be able to answer any questions.
Nice job - you'll be addicted soon.
http://lumberjocks.com/rance
Rance made me say that….
...and his wife, Ethel, too.
i checked out his stuff, and the ring he made looks pretty awesome (might have to try that myself), but it's not nearly the same technique :)
Nice job on these rings. It looks like you've already mastered the process. Keep up the good work.
Nevermind Rod, he is delirious. :) I'm actually quite witty but only sometimes clever. I've not posted any of the bentwood ones I've done, but I will soon.
Never mind Rance, he's comatose.
He has a bunch of bent wood rings and others he's been working on.
He just produces stuff faster than he can get them on LJ.
you two are goofballs.
well, i'd love to see your work!
