Project Information
My first attempts at using Alumilite casting resin for turning projects. Got some inspiration from NZ Wood Turning. I used the Alumilite clear and I did also make the pressure pot to remove all air bubbles from the casting. I went the less expensive Harbor Freight route outlined by Zack Higgins. I estimate that the resin works out to about $1/ounce. There are about 10 oz in the baby block jar and 4-5 in the pencil bowl.
Cool stuff, turns and sands nicely.
Gallery
Comments
Something different…. I really think this is cool and a fun project. Nice job!
Looks quite impresive this epoxy game.
Pencil bowl is mesmerizing. I like that the pencils are haphazardly strewn rather than perfectly laid in.
Very cool! The pencil bowl looks very vibrant.
Rick, I like what you done, very nice.
I also would like to make pressure pot for Alumilite .
I tried looking up Zack Higgins pressure pot. But that didn't lead me to answer. Would you please tell me where to find information to build the pot.
Thank you
Bruce try this
Rick, Thank you. Just what I needed to know.
Bruce- some of the fittings use Locktite and are difficult to remove. I ruined my safety pressure relief valve but learned after the fact to use a torch to heat the fitting And it will come out much easier.
Real eye catcher Rick, nice job
Pete
Very cool! I really like the pencils.
You do such great work, now I know what you mean by a pressure pot. sound like it should be called a vacuum pot.
